It is currently Sat Nov 28, 2026 12:06 am
Post new topic  Reply to topic  [ 70 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Wed Dec 24, 2008 6:17 pm
April 1st?
No, december 24. No pictures till we feel like it. Bitches just dont know.
PostPosted: Thu Dec 25, 2008 6:57 pm
a chevy head on a slant!? thats so not kosher. suddenly i feel less bad about entertaining thoughts of putting a 350 under the hood of the scamp
What's that fuzzy blue thing being hurled this way?
::stick::
BOOSH!!!
PostPosted: Fri Dec 26, 2008 7:55 pm
well I am sure I am going to get some hate mail, I am buying a Nissan 3.0 v6 for $150, I am putting my Eaton M90 blower on it and switching it over to a carb from the stock EFI.
PostPosted: Mon Dec 29, 2008 1:09 am
My understanding was that I should run this head for a full 6 months before I say anything.....did you guys change your mind? Can I just tell everybody?
What about the coolant leak?
Hey Sandy,
Keep running it and report back to Doug just like you've been doing. I think Doug may have figured out an ingenious way to solve the coolant leak without interrupting flow like we thought. :wink:
PostPosted: Mon Dec 29, 2008 2:54 am
Ok, cats outa the bag.
How about an early Christmas present for the enquiring minds that want to know?
Same here Fessup!!!!
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Tue Dec 30, 2008 7:09 am
I just run it low. Too cold to need much cooling.
Im tired of trying to time 2 cams.
PostPosted: Sun Jan 04, 2009 4:04 pm
Hi rob... We had a Opel with 3.7 or 4.1 inline six - over here was caled the chev 4100 or 3800
http://www.fmm.co.za/HTML/car_detail.jsp?id=3130
Most likely the 3.0 DOHC from late Omegas and Carltons. About 200hp stock and 370 hp or so from the turbo'd and breathed on ones that were tuned by Lotus.
UPDATE: I did a little investigation and it appears that the Opel/Vauxhall straight six came in both 12 valve and 24 valve flavours the former having a single camshaft. Unfortunately it's not a cross flow design and both the intake and exhaust manifolds are on the righthand side of the engine which would make it pretty cramped on a slant six.
PostPosted: Mon Jan 05, 2009 7:35 pm
As long as we are dreaming and talking out our @$$e$, that head would work fine if you flipped the cam and the head :lol:
Chris'
Autobody
Restoration
Service
PostPosted: Mon Jan 05, 2009 9:26 pm
Thing is - the engine I am refering to is a pushrod afair with the carb and ex on the same side as ours
Regards,
Fanie Gerber
PostPosted: Mon Jan 05, 2009 10:37 pm
Check this out:
http://www.customdesignperformance.com/ ... _head.html
Not sure if this motor has been discussed before. I just found it. The machine work is pretty impressive. It involves filling all the old water ports and head bolt holes and machining new ones in the deck.
At the bottom of the page, click on the link to go back to the index for the full story.
Users browsing this forum: Ahrefs [Bot] and 4 guests
