It is currently Sat Nov 28, 2026 2:23 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
 Post subject: I'm sorry, whatsa PM
PostPosted: Mon Jan 05, 2009 6:34 pm
PostPosted: Mon Jan 05, 2009 6:48 pm
A PM is a private message thru the board
Look at the bottom of someone's post and you can PM them....
PostPosted: Tue Jan 06, 2009 8:13 am
I guess what works for me, doesn't for other folks.
Hope you get it started.
 Post subject: Starting your rig
PostPosted: Tue Jan 06, 2009 6:32 pm
WD-40 is great stuff...it removes just about any lubricant or grease and doesn't leave any behind. I once saw what happened to a 500 kV circuit breaker when a nitwit electrican used a shot of WD-40 in place of white lithium grease. Ka-Boom and bye bye $1 million. We weren't too happy with that guy!
All the suggestions given are good ones about starting the rig. I think I would pick up a set of brake bleed screws (at least four, plus two more to sacrifice to the various automotive gods) and a jug of brake fluid and drain the brakes at least once. I was STUNNED at how funky and nasty the brake fluid was in the rig I brought back to life--remember that brake fluid absorbs water. Be careful trying to bleed the brakes though--the bleed screws might be rusted shut and immovable--PB Blaster, Kroil, or Liquid Wrench might help loosen them but don't break the screws out in the field if you can avoid it. FYI--if new brake lines are needed (they probably will be) I can only say great things about In-Line Tube and their pre-bent stainless steel tubes. Worth every dollar--cheap, cheap, cheap piece of mind for the life of the rig.
Hopefully you have a place suitable to do all this. I picked up my truck from a farm with no shelter and no electricity. Sunk to the hubs in pine needles. Crappy November weather as well. I broke all of the fine advice noted in the previous posts, put a new battery in, used a crappy one-time-use-and-it-breaks $15 cigar lighter air compressor to pump up the tires, poured a shot of gas down the mouse nest infested carb and cranked on it for about 1 minute. Vroooommm. Drove it 350 miles home on ugly tires and all the other assorted unknowns--I wouldn't do it that way if I could have avoided it...follow the advice given if you can. If you can't, well, just consider it a few extra thousand miles of wear...
Slanted D150
PostPosted: Tue Jan 06, 2009 6:40 pm
Hey, if shooting silicone into the engine makes you feel good, there might be some value in that.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 4 guests
