It is currently Sat Nov 28, 2026 10:31 am
PostPosted: Thu Jan 08, 2009 7:47 am
I've searched the forum,but haven't found an answer for this...
I'm slowly piecing together the super six setup for my 1980 d-150 truck. Right now it has a manual transmission and 1bbl holley 1920? carb. The new carb is a Carter BBD. Will I need any special throttle linkage/cable or will the stock setup work with the BBD?
Thanks in advance
PostPosted: Thu Jan 08, 2009 11:07 am
For best results, use the 2bbl throttle cable and bracket.
