It is currently Sun May 17, 2026 2:17 am
 Post subject: bigger fly wheel
PostPosted: Thu Jan 08, 2009 2:38 pm
i took apart the slant in my car the other day and i noticed that i flywheel was tiny i measutred it 11 inches and i wanted to go to a 9.25 inch clutch insted of 9 about would i have ot get a bigger flywheel and bellhousing or am i gonna just be able to turn the fly wheel a little bigger? i wanted to go with the zoom clutch
here
http://store.summitracing.com/partdetai ... toview=sku
thanks josh
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Thu Jan 08, 2009 3:08 pm
Post pictures of your flywheel with a tape measure across it..
Most likley it's the right one.. They only have 2; The car one and the mondo truck ones.. 9.25 and 10" clutches fit on the car one with no problems.
PostPosted: Thu Jan 08, 2009 4:51 pm
sorry its a 9.25 clucth i was usein a werid tape measure
PostPosted: Thu Jan 08, 2009 4:53 pm
You can also use a 9.5" clutch for a 273 car. If you want a serious upgrade Spec Clutch has some very high torque capacity 9.5" clutches with diaphragm covers which require less effort and travel than Borg and Beck clutch covers.
PostPosted: Thu Jan 08, 2009 6:30 pm
will it fit my flywheel though
PostPosted: Thu Jan 08, 2009 6:38 pm
Yes, that's why I brought it up.
PostPosted: Fri Jan 09, 2009 10:05 am
where could i get one
PostPosted: Fri Jan 09, 2009 10:20 am
SPEC clutch info:
Matt Rocksvold
1-800-828-4379
PostPosted: Fri Jan 09, 2009 11:45 am
:roll: http://specclutch.com/
You do know how to work Google right?
PostPosted: Fri Jan 09, 2009 12:41 pm
never had much luck with it
but thanks of all the info guys
 Post subject: clutch
PostPosted: Sat Jan 10, 2009 1:33 am
Actually, Borg & Beck made or maybe even still does a 10" clutch and pressure plate that will work with the typical 122 tooth flywheel. I have two of them, one going in my wife's Dart Sport and the other a spare. They're not rare or unusual and I've seen a few new ones on ebay as well. If you want something that'll work well and take some serious pounding, contact Tim Hyatt at Hyatt Racing 440.254.1311. He can build or modify just about anything you need or might have a desire for. Hope this helps...wb
PostPosted: Sat Jan 10, 2009 5:21 am
Dont use the Borg and beck 10" PP if you plan to do any racing...
More on that Here:
http://www.slantsix.org/forum/viewtopic.php?t=13007
And they are also readily available from napa, rock auto , Advance, parts america etc..
You have to get a 10" clutch plate to match.. again, reaidly available.. They have the same bolt pattern as the clutch and PP that you just took out.
