It is currently Wed Jun 17, 2026 10:38 pm
PostPosted: Sun Jan 11, 2009 11:54 am
Hi all,
I'm nearly done with the Super Six conversion on my '67 Barracuda, 225, and was wondering what everyone is using for an air cleaner housing. I took a chance and picked one up at last Fall Fling - found one from a '66 Charger 318, for $25. The diameter at the carb inlet looked correct, but I wasn't sure if the rest of it would fit. I've done a trial fitting, and it looks to be sitting a bit high. It may be okay - I still need to put some modeling clay on top and see just how close it is when I close the hood. In the meantime, I'm just curious what others have used. Thanks for any suggestions.
Roger
Image[/img]
PostPosted: Sun Jan 11, 2009 11:56 am
I have used the factory "Super Six" air cleaner, 318 air cleaners, and cheap chrome aftermarket air cleaner. The factory pieces are the best though.
PostPosted: Sun Jan 11, 2009 1:43 pm
good looking engine! i used an eldelbrock air cleaner with a adapter ring on my bbd when i had it. the best air cleaner i had was off a 318 it ift better and i could use a larger filter and i had the snorkel.
PostPosted: Sun Jan 11, 2009 5:36 pm
Thanks, MiDi. Most of my weekends since early August have been spent detailing my engine compartment, cleaning, painting and putting everything back together after an engine and front suspension re-build. This is as good as it's ever going to look. Unfortunately, it's all downhill from here! :lol:
I tested the fit of my 318 air cleaner assembly by putting some modeling clay on top of it and closing the hood. There's only about 1/16" clearance on the driver's side, and I'm not sure that's going to be enough. I do have the Super Six air cleaner assembly that I got with the carb. It sits a lot lower, but it's kind of beat up plus it has lots of air pollution hoses and garbage coming off of it. I may try modifying it, or else keep looking for something more suitable. Thanks for the replies.
Roger
PostPosted: Sun Jan 11, 2009 5:46 pm
sandblast the super six housing and paint it, then hook up that "garbage" and get it working properly, it will increase performance and fuel economy.
PostPosted: Sun Jan 11, 2009 6:33 pm
Car Model: 1967 Dodge Dart 270
I used the stock 1bbl air cleaner off my 67 Dart. It took some mods and welding to make it work but it look great. I wanted to keep my car close to stock as possible.
PostPosted: Sun Jan 11, 2009 6:36 pm
awesome brian, i'm gonna mod the super 225 1bbl air cleaner to fit a 2300 2bbl for my truck. got picts?
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 2 guests
