It is currently Sat Nov 28, 2026 9:07 pm
PostPosted: Tue Dec 30, 2008 6:55 pm
Thank you for the info,my alum block motor with a fram would take a couple seconds after fire up for oil lite to go out if I didnt start it for a couple days,switched to napa 1515,and it goes off alot quicker,will try the 1806 next time,and all future changes,from what I have read,the 1806 is the best thats available for any slant,thanks again,Mark
 Post subject: buying in bulk
PostPosted: Sun Jan 11, 2009 9:31 pm
As an FYI, I have had good experience buying filters online from www.fleetfilter.com. You need to buy enough filters to make the shipping worthwhile but that's never been a problem for me since I have a big fleet of cars that use the same filter.
PostPosted: Sun Jan 11, 2009 10:31 pm
I think Dan posted this link before. Free shipping on orders $50 or more and great prices.
PostPosted: Sun Jan 11, 2009 11:56 pm
A little off topic here, but I found that the tall filter (the tall 30001 Purolator filter) was so close to the block on my '83 engine, I couldn't put my filter wrench on it to get it off. Is this the reason Chrysler used a short filter on hydraulic motors? Thats what is called for, and what I'm going to go with from now on, just for ease of removal and instalation. I used what ever the CarQuest number is, they are made by Wix also (oil is made by Valvoline, just like Napa). I change oil every 3K anyway.
PostPosted: Mon Jan 12, 2009 7:10 am
Huh? I need more coffee,To close to the block? or to close to the inner fender?
PostPosted: Mon Jan 12, 2009 7:37 am
Does Fram make a filter with the anti drainback valve and the built in standpipe? I've noticed an anti-Fram sentiment on the forum, educate me.
I'm sure I can do this without disconnecting the battery. What could possibly go wrong?
PostPosted: Mon Jan 12, 2009 7:50 am
Oops! never mind, finally learning to use search function instead of just asking whatever question falls out of my head! thanks for the info. This is the best forum ever.
PostPosted: Mon Jan 12, 2009 3:05 pm
i hate filter wrenches, i use a bigass pair of channel-locks. the jaw capacity is 6". ive used these pliers on every filter imaginable on all sorts of construction equipment, cars and trucks, the only ones i have trouble using them on is the 4.3GM V6 filter tucked into the oilpan, and most imports where the filter is buried under hoses or something. when the channellocks dont cut it, i use a seatbelt filter wrench, they are easier to manipulate and you can use a ratchet extension in tight clearance applications.
i bought a case of PL30001 filters for $50 from an in-town wholesaler, and i'm about half through it now. i like the extra capacity.
PostPosted: Mon Jan 12, 2009 5:50 pm
Those of you that don't frequent Moparts.com is the oil filter deal in the "Moparts Hot Deals and New Products" section.
I need to buy filters for everything including the Cummins.
PostPosted: Mon Jan 12, 2009 8:34 pm
Oil filter deal is here.
