It is currently Thu May 28, 2026 12:08 am
 Post subject: Radiator Question
PostPosted: Fri Jan 16, 2009 8:14 pm
Will the 22" rad from an '80 Aspen (/6 car) go into My '70 Dart without too much hacking?
Thanks in advance,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Fri Jan 16, 2009 9:09 pm
It is close. I have never done the swap myself, but I have heard other people say it isn't too hard.
PostPosted: Sat Jan 17, 2009 8:03 am
Thanks Reed,
I'm pulling it tomorrow. Will I need different hoses? If so, are there silicone or other high quality hoses available for the slant?
Thanks again,
Nat
PostPosted: Sat Jan 17, 2009 8:38 am
Also, does anyone have any tips on cleaning out a radiator (short of disassembling and rodding it out) prior to installation?
PostPosted: Sat Jan 17, 2009 9:20 am
not to sure about that swap but the radiator out of a 76 aspen fit perfectly in my 64 dart had to drill two new holes in the flange on the radiator and diffrent hoses but fit perfect.
if im not mistaken the stock upper hose will work but you will need this lower hose from advanced auto (E)71713CS
64 dart GT /225
...........____ .
...._n_.[____].
.....L\....\......
.......\____\....
