It is currently Thu Oct 01, 2026 8:11 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Sun Jan 18, 2009 7:49 pm
When I found it, I thought it was a creepy Winnie the Pooh van after Reed brought it to my attention. It might as well have said "Free Candy"
ROTFL!! Now how the hell am I supposed to clean all this cola off my keyboard?
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Sun Jan 18, 2009 8:24 pm
That's from a couple weeks before I found the owner. The van is safe now (except for all the snow around it)... bodywork coming up in spring!
Sorry about your keyboard!
sasktrini, Saskatoon, SK, Canada
'68 Fargo A-100 Van, 225, A727, 8 3/4" rear axle
PostPosted: Tue Jan 20, 2009 12:08 pm
Hello, I'm new here.
I recently acquired an 86 Van with a /6 in it. It runs, but won't go past 50. It does have an automatic trans in it, but it leaks like a sieve.
And yes, it's ugly.
I want to bring it back from morbidity. Can y'all help me?
Thanks
PostPosted: Tue Jan 20, 2009 12:43 pm
where are u located Pinecone? and where does the van leak?
try to give us some more info so we can better help you, and Welcome to the forum!
PostPosted: Tue Jan 20, 2009 2:19 pm
I'm in Albuquerque. The trans appears to be leaking from the front seal and the pan. It does start fairly easy and will idle fine. When at idle, however, it appears to be idling too rich (black sooty exhaust). I need to do a compression test on the motor to see if it's worth spending money on the old thang. I got for next to nothing ($25).
As far as the lack of speed is concerned, only thing I haven't tried yet is unbolting the cat. It may be clogged.
And thanks for the welcome. :D
PostPosted: Sat Jan 24, 2009 12:54 pm
Heres my "ugly",but hay.beauty is in the eye of the beer holder.
GIT R DONE
[IMG]http://i339.photobucket.com/albums/n450/lloydhuff/Christmas08-s
now008.jpg[/IMG]
oopps try try again
PostPosted: Sat Jan 24, 2009 12:57 pm
Ugly but mine
PostPosted: Sat Jan 24, 2009 1:35 pm
Ugly but mine
How many joggers have you decapitated ?
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Sat Jan 24, 2009 4:18 pm
Actually I try to avoid joggers at all cost both public and private.I have done a most remarkable job of cleaning the bits and pieces of bicycles and fanny packs off the front don't you think? :twisted:
PostPosted: Sat Jan 24, 2009 4:48 pm
From the picture it appears that your side mirrors stick out a good ways :D I dig the extended cab
Dave
81 Dodge D150
PostPosted: Tue Jan 27, 2009 12:59 pm
little bit of paint and it will be good as new I like the mirrors you have to be able to see the stuff behind you before you run it over
Nothing beats a slant six
1987 D150
