It is currently Sun Nov 29, 2026 6:47 pm
PostPosted: Tue Jan 20, 2009 7:23 pm
I need to find an adapter plate for my holley 8007. I have an adapter that works but I can only mount the carb with the primaries mounted either fwd or aft. I want to turn the carb so its mounted primaries way from the engine. I searched here and saw frank raso had some at one time but cant find them listed anymore. The manifold should be an early offy it has no numbers or name on it. Am I just going to have to make one?
PostPosted: Tue Jan 20, 2009 7:26 pm
You have to drill out the holes in the your adapter to turn the carb sideways. The Clifford adapter has oval holes to mount the carb sideways or fore/aft. I run the Clifford adapter on my Offy manifold.
PostPosted: Wed Jan 21, 2009 4:59 am
you can turn the Offy adapter that came with the intake. 2 screws lne up. Just drill out the other 2 and you should be good to go!
PostPosted: Wed Jan 21, 2009 10:41 am
That item is still available. I've just removed it from my estore temporarily. Send me a PM if you're still interested.
Frank
