It is currently Wed Nov 11, 2026 9:39 am
PostPosted: Wed Jan 14, 2009 5:42 pm
I pulled the dash/gauge panel on my 67 Barracuda, but I don't see the voltage limiter on the back side (like my 73 Dart three prong VL). Is there one? If so, where is it located?
PostPosted: Wed Jan 14, 2009 10:03 pm
it may be in the gas gauge like my 66 a100 - if not someone will have the answer soon - oo3
69 a100 225 tree3
 Post subject: vr
PostPosted: Sun Jan 18, 2009 7:08 am
I know for certain it is in the fuel gauge.
 Post subject: Re: vr
PostPosted: Tue Jan 20, 2009 10:08 pm
Can this be replaced by a solid state unit? I have my gauge panel apart right now, and the gauges are crimped together. Can the gas gauge be taken apart without ruining it?
PostPosted: Tue Jan 20, 2009 10:38 pm
Answer is yes, but that's not relevant to your situation; 1965 was the last year the voltage limiter was built into the gauge on A-bodies. If you haven't found it on your '67, it's because it's absent or you haven't spotted it yet. It is the external plug-in type.
PostPosted: Wed Jan 21, 2009 1:49 pm
This link SSDan posted sounds like a great upgrade to protect the gauges. I'd venture to say this would affect you as A Body rallye dashes (such as you have) have the limiter incorporated with the gas gauge.
PostPosted: Sun Jan 25, 2009 1:25 am
Thanks for the link. My fuel gauge has the three bolts coming out as pictured in the link, and there are no slots for a VL to plug into. I may have to try the solid state one. I don't really want to pull the dash again if I don't have to.
 Post subject: gauges
PostPosted: Sun Jan 25, 2009 8:51 am
I did my 68 cuda 6 years ago.pry apart the gauge,removed the vr with a dremal tool,and put a 7805 regulator mounted to the back of the pot metal dash. Mopar action had an articule on this in aug 2000
