It is currently Sun May 17, 2026 12:20 pm
 Post subject: 340 Springs
PostPosted: Wed Jan 21, 2009 3:52 pm
I have a question I would like to get answered. I see that a lot of people are using the 340 springs in the /6 heads with the bigger valves the question I have is are you running the double spring setup or a single spring setup? the 340's I ran used a double spring set up so just trying to figure out what I need for my /6.
Thanks
PostPosted: Wed Jan 21, 2009 4:30 pm
The factory 340 spring is really a single spring with an inner "flat wire" damping coil... it looks like a double spring but it's not.
PostPosted: Wed Jan 21, 2009 4:47 pm
The reason I ask is that I found a set of 340 springs on ebay for 38.00 and asked the same qustion and the seller told me they were a single spring and I know that I had a double setup so what is everyone running springs with or without the coils.
Thanks
PostPosted: Wed Jan 21, 2009 6:30 pm
I used stock 340 springs w/o the damper. :shock:
 Post subject: 340 springs
PostPosted: Wed Jan 21, 2009 6:33 pm
Is $38.00 a good price for a set of 12 new springs
PostPosted: Wed Jan 21, 2009 6:38 pm
I am running my 340 springs with out the damper also.
PostPosted: Wed Jan 21, 2009 7:01 pm
Why? The damper is there to reduce spring surge.
PostPosted: Wed Jan 21, 2009 8:18 pm
Do you need to take metal off the spring seat area in order to use the damper?
PostPosted: Wed Jan 21, 2009 8:25 pm
The 340 spring drops right in no machining required. I do use larger retainers though. We've been over the retainer issue before. I even posted pictures.
PostPosted: Wed Jan 21, 2009 8:55 pm
do you happen to know or have a good part number for the retainers and if I understand you correctly I should be looking for springs with the dampners installed
PostPosted: Wed Jan 21, 2009 9:27 pm
The Comp Cams retainer in a set of 12 is 744-12 or a set of 16 as 744-16. The 340 type springs are 901-16. It's more expensive to buy 12 individual 901 springs than the set of 16. I wish Comp had the 901 spring in a set of 12, but it doesn't appear that they have anything other than individual springs or sets of 16.
PostPosted: Wed Jan 21, 2009 10:58 pm
Thanks Joshie for all the info
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 5 guests
