It is currently Mon Nov 16, 2026 8:46 pm
PostPosted: Sat Jan 31, 2009 9:18 pm
I want to put headers on my slant, but there does need to be at least some kind of intake heat, or there's going to be trouble :)
I don't need a choke well...
So, would it work OK to divert some flow from the water pump and run it through the cavity on the bottom of the intake? Seems like a thick aluminum plate with a good gasket seal and a couple of strategically located holes for water inflow and outflow with hose barbs on them ought to work...
What do you think?
PostPosted: Sat Jan 31, 2009 9:42 pm
See earlier threads (like this one) about intake heat.
I have one on my car and it works extremely well.
