It is currently Mon Jul 06, 2026 10:10 pm
 Post subject: accelerator pump
PostPosted: Tue Feb 03, 2009 7:33 pm
i noticed today when i was fiddiling around that im not only getting a 1 sided pump shot from my accelerator pump from my bbd. so my dad told me to use a cuetip and put over the hole and and blast what ever is in there out. it slightly worked but just a weak stream came out.....then i took a paper clip and put in the hole.......it would free it up then i would pump it.. both...both....both....unclogged one...unclogged one and so forth. so either side works but not both at the same time. if your confused i understand.
what could be my problom?
ive looked for ideas in the great pdf file dan made...but i couldnt find any ideas
hopefully ill fiddle with it tomarrow.....so andy ideas are welcome :D
PostPosted: Tue Feb 03, 2009 9:04 pm
Your problem is most likely a worn out accelerator pump cup. This is a wear part that will wear out with time. Get a god rebuilt kit and replace the pump gasket.
PostPosted: Wed Feb 04, 2009 5:48 am
maybe take the squirter nozzle off and see if there is trash in there. Don't do it on the motor as there is a check ball under there that when you hit the throttle. It can pop out and go down into the intake.
PostPosted: Wed Feb 04, 2009 1:51 pm
just got it worked out....switched the venturi cluster from a spare bbd...and wala it works great.
PostPosted: Thu Feb 05, 2009 5:33 am
That is cool! Did you find trash in there?
