It is currently Sat Jun 06, 2026 5:31 am
PostPosted: Wed Feb 25, 2009 11:16 am
The image below should help with some of the basic cam lobe design terminology.
PostPosted: Wed Feb 25, 2009 11:39 am
Great diagram.To be more specific, I was wondering how a change in lash settings and ramp design affects duration. I'm thinking the looser the lash setting causes a delay in the activation of the valve, hence less duration. Is that correct?
Blair Furlotte
1979 Dodge Aspen 225 "Super Six" 3-speed
Original owner
PostPosted: Wed Feb 25, 2009 11:55 am
Yes, later opening and earlier closing.
PostPosted: Wed Feb 25, 2009 3:04 pm
Yes, this is exactly why the industry started to use the "@ .050" checking method, it takes the lash ramps out of the measurment.
BTW, lash ramps come in many "shapes and sizes", depending on the application and even the valve train type it is used with. (intake, exhaust, heavy, light, hydraulic, roller, etc.)
PostPosted: Thu Feb 26, 2009 12:08 pm
Just spec 230 @0.050" int and 220 @ 0.050" exh with about 0.460-480" lift. If this is Oregon Cams, they have a good rep and can help you properly.
Thank you Lou. I called Oregon, but am using Delta Camshaft in Tacoma. I must have gotten the wrong person on the phone at Oregon Cams, as they didn't sound as knowledgeable or helpful? And they were more expensive...
PostPosted: Thu Feb 26, 2009 12:39 pm
Does Delta have a good custom regrind reputation? What is their price for a regrind?
I am open to regrinders, just limited info on who's out there.
Thanks,
PostPosted: Thu Feb 26, 2009 1:26 pm
If you call Oregon Cam Grinding you need to be able to tell them what you want and it's best to speak with Ken Heard. It's not difficult to look at the spec sheet and pick out the lobe profile(s) you want. There are slant six folks and there are cam grinding folks. I don't think we'll ever find one that's both. I would never call any cam grinder and ask for their recommendation for a slant.
PostPosted: Thu Feb 26, 2009 8:00 pm
Expensive? That doesn't sound like them. They priced me $105 for reground lifters and cam. I think I'm going with a 270 grind similar to the Erson one. OregonCam guys are nice and helpful, but they don't seem to have absolute knowledge about the slant which shouldn't be fully expected.
PostPosted: Mon Mar 09, 2009 4:18 pm
I'm running the 270 erson on a 108lobe center love it plenty of torque and mine pulls to 5500rpm, 6000rpm if i wanna stretch first gear.
Kev
 Post subject: Lol...
PostPosted: Mon Mar 09, 2009 5:53 pm
It's kind of interesting looking at the 'manners' of the Erson cams, it looks like the 270 would be nice for 'street/strip' use if the compression and LSA were chosen carefully...the 280/270 looks to sacrifice a bit of low end torque for a bit more 'topend' power....
"For the street engine and a heavy car...10 ft/lbs of torque in a lower RPM band may be worth more than 10 HP at the top end..."....
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 5 guests
