It is currently Sun Jun 21, 2026 12:41 am
 Post subject: oil pan
PostPosted: Thu Feb 26, 2009 2:05 pm
putt'n the oil pan on the block and the factory manual doesn't really do it justice, what do I do with the overlaps in the front of the pan? Cork to rubber. trim them or will the 200ft lb torque fix this?
PostPosted: Thu Feb 26, 2009 2:17 pm
Site Admin
200 Wha...! :shock:
http://www.slantsix.org/articles/gasket ... n-seal.htm
Yer kidding about the 200ft-lb, right? :lol:
CJ
PostPosted: Thu Feb 26, 2009 2:25 pm
haven't done it yet, but thought thats what the book said FRM= factory repair manual
PostPosted: Thu Feb 26, 2009 2:36 pm
I'm not sure I'd even believe 200 inch-pounds, but it is much more reasonable. Those little 5/16" screws would have to be made of unobtainium to withstand 200 foot-lbs.
PostPosted: Thu Feb 26, 2009 3:52 pm
A 100-110 in lbs maybe....I wouldn't even try 200.
PostPosted: Thu Feb 26, 2009 6:34 pm
Grade 5, dry, 5/16-18 bolt torque specs are typically about 17 ft-lbs.
200 inch-pounds (what my FSM says) is 16.7 ft-lbs.
PostPosted: Fri Feb 27, 2009 1:54 am
I just put my old engines oil pan on a "new" used motor for my truck, the other day. It was a fel-pro gasket and called for 100 inch pounds, that was squishing it pretty good. I wouldn't go more than that myself. = 2 cents
Dietz
for profiles and pictures of my mopars--> http://www.fquick.com/dietz_diggler
PostPosted: Fri Feb 27, 2009 8:16 am
thanks everyone, will do lot less torque, and thanxs for the pictured info topic. helps tremendous.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
