It is currently Sun May 03, 2026 7:23 am
PostPosted: Mon Mar 31, 2003 9:17 am
How do you remove the rear pinion seal??
I am replacing the pinion seal in my 63 Valiant. I am trying to save the leaky 7 ¼ rear until I get everything together for a swap.
I have removed the yoke. It looks like is should be smooth sailing from here if I could just get the seal out. I have tried to use a large screwdriver. That just sort of bends the seal. I have tried to use a small screwdriver. That just sort of bent the screwdriver. I just can’t get the thing to budge.
It’s the older seal with what looks like leather instead of rubber.
Any tips here would be appreciated.
John Killin
 Post subject: The Seal is Out
PostPosted: Tue Apr 01, 2003 8:22 am
I was able to get seal out last night.
I used a "seal puller" that I got at Discount auto. Go figure.
I just need to reconnect the drive shaft and add new fluid and I should be good to go.
John Killin
PostPosted: Tue Apr 01, 2003 9:18 am
Good work John,
I will have to go look at one of these "seal pullers", most of the time I just mangle the old seal with a punch or screw driver to get it out.
PostPosted: Tue Apr 01, 2003 10:07 am
I had a bad experience with one of those seal pullers. Gives me the willies to think about it.
PostPosted: Tue Apr 01, 2003 12:24 pm
The puller looks like a screwdriver with a hook on the end. Just wedge the point under and pry.
Mangle is the key word here.
The seal was definitely mangled. The puller just gives a bit more mechanical advantage than I was getting from the screwdriver.
I tend to get nervous when and am applying what feels like excessive force with out results.
Once it was ready to go, it popped right out (about 3 feet).
John
