It is currently Sat Jun 06, 2026 6:54 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Sat Feb 28, 2009 4:03 pm
After doing some reading about 4x4 truck rear disc conversions I decided to try leaving the stock 75 valve in the Valaint when I went to 4 wheel disc. It stops very nicely without any extra prop valve.
If the brake proportioning is right for drums ....its likely right for correct sized discs. I used Explorer 8.8 rear and discs.
Id try the stock setup before messing with anything extra.
PostPosted: Sat Feb 28, 2009 8:56 pm
To swing the thread back, as I'm talking with the previous owner, Delphine (the Dart) always pulled right. Also the master Break cylinder is from a 75. Is it common to change the Break cylinder when doing a disk conversion?
My Car Domain
PostPosted: Sun Mar 01, 2009 10:23 am
I agree with dakight and emsvitil, your problem is probably a caliper or hose. You can convert an all-drum master cylinder by removing the residual pressure valve for the front brakes, but it wouldn't be as good as a purpose-built one, where there is a lower pressure valve for the front. That way the calipers are ready to go, but not dragging.
