It is currently Fri Jun 19, 2026 1:25 am
 Post subject: oil pickup tube
PostPosted: Sun Mar 01, 2009 1:43 pm
Good afternoon to all,
I would like to know of any tricks to get the oil pump pick up tube removed from the engine. I have teh oil pan off and the pick up tube looks clogged and want to remove it to try and clean it. the engine itself is spotless I just picked up this car and the owner told me it was a remanufactored block which it looks like zero miles on the enging but the oil pick up screen is filthy and looks clogged so I want to remove it and clean it.
Any help would be great.
Thanks
Ron
PostPosted: Sun Mar 01, 2009 1:49 pm
Turn the tube counterclockwise. Be prepared to rotate the crank to clear the tube.
PostPosted: Sun Mar 01, 2009 2:31 pm
I've tried that I even tried with a pipe wrench on it and its not moving, and I dont want to brake it, any other ideasto get it to break loose
PostPosted: Sun Mar 01, 2009 2:52 pm
Hit it with a rubber mallet. Counter clock-wise.
PostPosted: Sun Mar 01, 2009 3:14 pm
Thanks
I got a bigger pipe wrench and a long pull bar and got it to break loose. I knew I could get the advise I needed on this site.
