It is currently Fri Jun 05, 2026 11:55 am
 Post subject: 9" or 10" ?
PostPosted: Sun Mar 01, 2009 7:22 pm
How do I measure to see what size drums I have on my 1974 Dart Custom? I'm trying to figure out if I have tens in back. I plan on putting disc brakes on the front and the 10" rear, disc front combo I had on my 75 worked great.
If I have 9" rear drums, would you recommend replacing them with 10s?
Thanks
M
God took you away, then brought you back to me.
 Post subject: Re: 9" or 10" ?
PostPosted: Sun Mar 01, 2009 7:36 pm
Remove one tire from the rear axle and see what MAX DIA. is cast into the drum. That will tell you your drum size.
Thanks
M
Upgrading to larger brakes is always a good idea.
PostPosted: Mon Mar 02, 2009 4:00 am
You can measure the inside diameter of the drum with a ruler or measuring tape.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
