It is currently Sun Jun 14, 2026 7:01 pm
 Post subject: Guzzi car dyno results
PostPosted: Mon Mar 02, 2009 7:28 pm
After doing my best to get the car right,I took it to the dyno today,first pull was 186.5 at 5450 rpm max torque 195.1 at 4850.
11 pulls later,,, changes inbetween,dyno guy and me got it to 189.0 @5450 max torque 200.8 @4850. He was very surprised and a little pissed off that he only got 2.5 more hp out of my seat of the pants tune,AND alot of help from this list,THANKS ALL,moto guzzi mark
PostPosted: Mon Mar 02, 2009 8:23 pm
Cool! Next up, time slips!
PostPosted: Mon Mar 02, 2009 9:29 pm
:lol: Better bring your own helmet this time!
TF
Even in moderation i am excessive!
PostPosted: Mon Mar 02, 2009 9:57 pm
Kinda scared,what is a 189 rwhp,2675lbs car,wih driver capeable of doing in the 1/4?,,,I wanted 200 hp and a car weighing in at 2600,missed both,Next motor will be over 200,I think Mike Jefferys is the key on next build,mark
PostPosted: Tue Mar 03, 2009 1:12 am
From this site http://www.wallaceracing.com/Calculators.htm
14.09 @ 95.09mph :D
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Tue Mar 03, 2009 5:32 am
I dont believe those calculators...there a good place to start but Ive seen dynoed cars against the calculator and they have been of by 40%
Just my 02.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Mar 03, 2009 6:27 am
You should be right on the 14.00 boundary. Slant will have a broader HP peak than most, so you should pull into the 13s. Heck, if you ran high 13s before, this motor should have a little more stank, right?
PostPosted: Tue Mar 03, 2009 6:53 am
I think you will be pleasantly surprised with your new set up. My car dynoed at 186HP with the a 236 degree at .050 cam and 500 Holley 2BBL.
With that set up it went 13.96 at 97MPH. Your car is 100# lighter and more importantly you have the auto trans that soaks up a lot of power on the dyno but will get you down the track much better than my wide ratio OD trans and granny shifts. You shold be good for middle 13s in good conditions but it won't go that fast at Las Vegas. Have fun.
PostPosted: Tue Mar 03, 2009 7:17 am
Max,
What carb are you running? and what is the jetting?
PostPosted: Tue Mar 03, 2009 7:30 am
Poser
Max, if you have 189 at the rear wheels, your engine should be 200 hp or more right now. Not an expert but I thought the rule of thumb was about 15% loss from engine to pavement.
PostPosted: Tue Mar 03, 2009 8:28 am
600 Holley,64 primarys 68 secondaries,8.5 power valve,lighter yellow spring,mark
