It is currently Sat Jun 13, 2026 6:05 pm
 Post subject: exhaust flange gasket
PostPosted: Tue Mar 03, 2009 5:56 pm
Car Model: 1964 Valiant V200
I got the nice aussie composition gaskets for the manifold and heat riser, and thanks to them no leaks there, but the gasket connecting the manifold to the exhaust system promptly blew out. I used a generic Fel-Pro one from NAPA, I seem to remember my wife's old Dart had the same issue but I can't remember how I solved it.
is there something I'm overlooking? It's easy enough to change out, so I will do that in the next couple of days.
PostPosted: Tue Mar 03, 2009 6:01 pm
Remflex #6006
I want to buy stocks in Remflex after using their stuff.
PostPosted: Tue Mar 03, 2009 6:03 pm
Yeah I used remflex gaskets in my Subaru WRX which has a million flanges in the exhaust system and lots of exhaust side pressure. They're good stuff, but cannot ever be re-used.
PostPosted: Tue Mar 03, 2009 6:08 pm
They said they can be re-used, but the only one I tried to re-use blew out completely so it's difficult to say.
PostPosted: Tue Mar 03, 2009 7:27 pm
Make sure the flanges aren't warped........
 Post subject: Remflex gaskets
PostPosted: Tue Mar 03, 2009 9:30 pm
I have reused them with no problems on the exhaust pipe fitting.
I your going to run your engine for a race then tear it down and want to reuse them again, just spray on some PAM to each surface. That way they won't stick. That goes for the manifolds or exhaust pipe gaskets.
PostPosted: Wed Mar 04, 2009 8:03 am
I reused my Remflex exhaust flange gaskets once so far. Still seals. (I have dual exhaust, so I have two)
PostPosted: Wed Mar 04, 2009 11:44 am
Cool, thanks for the advice. The only reason I worry is because I plan to rebuild the motor soon and would like to save $ wherever I can.
PostPosted: Wed Mar 04, 2009 12:23 pm
Ordered from amazon.com $13.50.
Anybody remember when az.com was just books?
Anyway, thanks for the advice.
PostPosted: Wed Mar 04, 2009 12:33 pm
Good point!... torquing the snot outta them is what causes it I imagine. Some quality time with the file can cure that.
PostPosted: Wed Mar 04, 2009 12:48 pm
I have seen several vehicles where oversize exhaust has been installed and the muffler shop welds the pipe to the flange in such a manner that the upper edge of the pipe protrudes beyond the manifold side of the flange preventing the flange from properly seating against the manifold. The next tiem you have the flange unbolted, run a straight-edge over it and make sure the pipe doesn't protrude above the flange. If it does, just grind it down.
Otherwise, warping (as previously mentioned) or corrosion can cause gaskets to blow.
PostPosted: Thu Mar 05, 2009 12:08 am
Hmmm, that sounds familiar.... :lol:
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 4 guests
