It is currently Thu Jun 04, 2026 10:40 am
 Post subject: valve seal installation
PostPosted: Mon Mar 09, 2009 7:10 pm
http://tinyurl.com/aqk26z
Can this type of valve seal be installed with the valves held in there closed position with air pressure? Is there a special tool for this?
My guides are .500 with 11/32 stems.
PostPosted: Mon Mar 09, 2009 7:44 pm
Yep. The fittings are available at most auto parts places. The napa near me stocks them.
Why teflon?
Are you going with a positive seal due to oil use?
PostPosted: Mon Mar 09, 2009 7:47 pm
Air pressure will hold the valves real well. Even with a 1.44" exhaust and 80 psi there will be well over 100 lbs pushing on the valve. exactly how much depends on the actual diameter at the seat.
You need a sleeve over the stem to protect the seal. You can make one with shrink tubing. The other tool is just bar stock with a hole in it to push the seal on.
PostPosted: Mon Mar 09, 2009 8:05 pm
I thought the valve guides had to be machined so that a positive seal will lock on the guide? When I changed my valve stem seals, I used some (new) vacuum tubing stuffed into the cylinder, than rotated the crank toward tdc to lock the valves in place.
PostPosted: Mon Mar 09, 2009 8:42 pm
i use a piece of nylon rope in plughole ,rotate by hand till it locks against vavles....if you use air and have leak...valve will drop...then off with head
PostPosted: Tue Mar 10, 2009 6:30 am
http://www.slantsix.org/forum/viewtopic.php?t=29493
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
