It is currently Thu Jun 18, 2026 8:12 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Tue Mar 10, 2009 5:25 am
Hey Dan & Tophat
Have you tried the light duty lock tite or even nail polish. Just a thought. Although I think Dans problem is junk in the fuel/fuel system. Ive seen trash get caught on the seat or needle. Tune it up then run, all of a sudden trash goes thru and you have to retune.
BTW Pretty Dart.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Mar 10, 2009 6:24 am
Scribe or make a fine mark on the screws (as a reference point), drive as usual, then recheck to see if they actually are moving.
PostPosted: Tue Mar 10, 2009 7:37 am
Well, I do routinely remove the plastic mixture screw limiter caps from '69+ carbs. This allows full-range adjustment, but also takes away a stop on the mixture screw. A "safety wire" type arrangement (wire clip thru the screw slot or a new hole drilled in the screw head) would probably work fine as a retainer, but no such retainer should be needed. I have in the past wrapped the upper threads of the mixture needle with Teflon tape, and that's worked well, but it's really just helpful where the mixture needle turns too easily in the throttle body. This one's nice and firm. There's no trash in the fuel or carburetor — and if there were, the idle might've suddenly gone lean, but not rich. I will keep an eye on it and see what develops or if it's a one-off.
PostPosted: Tue Mar 10, 2009 9:04 am
Sorry to get off topic here, but wowzers thats a beautiful Dart! :shock:
Thanks!
Far as the BBS goes, I have never owned one that didn't end up with the problem you describe.
Odd. How many have you owned? This is the first time I've run into this with a BBS.
In the neighborhood of 6.
I refuse to run them anymore.
Okeh, send 'em all to me. :lol:
In fact, the one slantsixbob got from you had something odd occur with it as well, the end result being the entire carb flooding to the point of fuel coming out the top of the bowl where the accelerator pump rod goes through
That'd be a stuck inlet needle and seat. I always recommend looking carefully at the soft parts (gaskets, inlet needle, accelerator pump plunger cup) and renewing as necessary before installing a new OLD stock carburetor.
I've had much better luck with the 1920s
And me, quite the other way around; I've never met a 1920 I was quite all the way 100% happy with and prefer the BBSs.
Maybe this is one of those brand preference issues... for example:
I pretty much despise Fords in general, I've never owned one that ran properly, no matter how much work I did to it. Had a Mustang, did all the tuneup procedures with new parts, etc etc, it blew both headgaskets, and fried the C4 within a month following that. My Bronco II blew the engine at 129k miles, and my F-150... well I got rid of that before it had a chance to die.
Same may go for Carbs, I am preferenced toward Holleys, and everytime I get a carter (aside from the BBD) they fail miserably on me.
Maybe it's all in my head... :shock:
PM me your info, and I will round those Carters up.
~THOR~
PostPosted: Tue Mar 10, 2009 10:51 am
Long shot: try a valve adjustment? That can certainly give poor/rich idle and symptoms you describe. Hard to see how it would come on fast, but worth a look. Did the weather get warmer, thus causing hotter temps and thus tighter lash?
PostPosted: Tue Mar 10, 2009 11:16 am
Nope. Valves are adjusted fine. Again: The idle cleaned up just fine with an adjustment of the mixture screw (clockwise).
PostPosted: Tue Mar 10, 2009 11:41 am
Anothor 'vote' for some junk or build-up around the idle air/fuel needle screw... as soon as you move it a little, the crap "moves along" and the idle circuit starts workig better.
I just had this happen with our 66 Dart, it just started runng 'choppy'.
I re-adjusted the idle A/F and everything was back to normal... it ended up about 1/2 turn "out" more then it started but seemed "happy"... so that is where we left it.
I pulled the valve cover and "ran" the valve lash anyway... no real changes were needed there.
PostPosted: Tue Mar 10, 2009 12:12 pm
<shrug>....
In the case of my 900,000 km work truck things like that are just part of the day-to day. You realize your vehicle is in a constant state of flux and that you can never get your head around the hole picture for more than minutes. Eureka moments are few and far between.....and funky stuff just keeps on happening.
Its OK to not know whats actually happening if you can fix it or at least get home....
The least you can do is hang some crap off your mirror as a Talisman to the God of High Performance and Good Gas Mileage.
That little string of Kootenay beads has saved my butt countless times. The evildoers hate it.
PostPosted: Tue Mar 10, 2009 2:21 pm
Unless I'm misreading previous responses, yours is the first vote for crap on the idle needle, tho we had a couple votes for an inlet needle (float valve) problem. Anyhow, yep, I pulled the idle needle and turned it tip-first into a twist of paper towel, and came away with a nice big smudge of rust. Oh, ask me how much I love the fact that our gasoline is cut 10% with alcohol. :roll: I used up the rest of a can of carb cleaner blowing out the air bleeds and the idle bypass airway, readjusted the idle mix, and everything seems a lot happier — no more misfiring, and much cleaner-smelling exhaust (Mm-mm-good! :twisted:). We'll see how long it lasts.
PostPosted: Tue Mar 10, 2009 2:29 pm
Phaw. Easy for you to say…you probly snuck thru Toronto on a tipi run, found my Dart parked in the street, jimmied open the hood and richened my idle mixture in the dead of night, just to mess with me! :twisted: :lol:
Reed was right; I should've kept the dashboard chicken.
(Edit: With this post right here, I'm at 15 kiloposts! :shock:)
PostPosted: Tue Mar 10, 2009 3:23 pm
On my motorcycle, I put a blob of RTV on the idle mixture screw and spring to keep it from backing out.......
I also think a split lock washer would work (between spring and screw)
PostPosted: Tue Mar 10, 2009 3:41 pm
no one sneaks through Trauna......
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
