It is currently Fri Nov 20, 2026 8:16 am
PostPosted: Fri Apr 04, 2003 10:01 pm
Has anybody found the limit in tire size for early a-bodies?
I would like to set-up my '65 Valiant convertible for handling, with possibly 50-series tires. Basically, I would like the tallest and widest tires that will fit.
The best I could find mentioned elsewhere was 235/60/15 for the rear and something like 215/60/15 for the front. Is there room for more? I would probably go with 16" wheels, unless 15's are good enough.
PostPosted: Sat Apr 05, 2003 4:34 am
I have 245/60-15's on the back of my '66 Valiant. However, I did trim out the inside lip on the wheelwell and rolled a pipe through the wheelwells to open them up some. They do get real close to the front lower corner of the opening too. :shock:
Lou has some pretty big skins under his '64. He'll probably pop in and fill you in on that. :D
PostPosted: Sat Apr 05, 2003 10:23 am
I have fit 235-60-14 all around with some lip mods.
I also trim-off the sharpe corner at the lower front corner of the front fender, that helps a lot. Getting the car real low also helped me some.
 Post subject: My experience
PostPosted: Sat Apr 05, 2003 2:52 pm
My '66 Dart is running 225/50R16 tires on all four corners. I did have to roll the front fender lips a little to make this work.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Apr 05, 2003 5:35 pm
Hmm... 225/50/16 front and 245/50/16 rear should work then?... though might be a little tight.
http://www.miata.net/garage/tirecalc.html shows the 245/50/16 just a little shorter than a 245/60/15... or a 235/50/16 is about the same size as a 235/60/14.
Anybody have pictures of the fender mods?
1965 Valiant Custom 100 Convertible
PostPosted: Sat Apr 05, 2003 8:00 pm
I did a slight amount of trimming on my '64 Dart front fender lips, and I have 245/45-16s that don't rub. The rears are fine if you get the wheel offset right. I am betting with some widening (like Dennis' pipe trick) I can maybe get 265s or 275s under the back of a '63-66 Val (my next project).
http://home.nc.rr.com/madsenkaestle/Dar ... 2202_2.JPG
Hope this helps,
 Post subject: tires
PostPosted: Tue Apr 15, 2003 7:05 pm
Any more pictures?... That Dart looks great.
What are the specs on your wheels?
PostPosted: Wed Apr 16, 2003 7:14 am
Thanks!
Wheels are 16X8 SSR Integral for a '90s Mustang with 5.72" backspace, running thin wheel spacers. More pics and answers are here.
http://www.slantsix.com/UBB/Forum4/HTML/000051.html
 Post subject: Semi-related question
PostPosted: Fri Apr 18, 2003 1:48 pm
What is the biggest tire you could fit under a 66 Cuda with a 14x8 rim? How about a 15x8 rim?
Reed :?:
