It is currently Thu Jun 18, 2026 7:04 am
 Post subject: Chugging at high speed
PostPosted: Wed Mar 11, 2009 5:07 pm
Car Model: 1986 D100 /6 A833od shortbox
Lately my '86 has started what sounds like chugging or missing at rpms over 3000. I just swapped plugs and the 1 and 6 were mat black, while 2 thru 5 were fine. Idles smooth, timing is just a tick ahead of ten (per a seasoned Mopar mechanic) Any suggestions?
Back story: '86 Ram D100 with what I am finding out to be a pieced together 1 bbl 225. I do occasionally have a sticky lifter, but it unsticks after a minute or two.
PostPosted: Wed Mar 11, 2009 6:36 pm
I forgot to mention, it does not always do this. Earlier today it was running awsome at speed. Went to work for 4 hours, came out and it was chugging again.
PostPosted: Wed Mar 11, 2009 7:22 pm
Site Admin
You have a tough one. Intermittent stuff is a bear.
What 1 bbl are you running? Engine temperature?
Being intermittent, fuel delivery, or an issue with the EGR maybe.
Is it like a lean surge at cruise? (If you mash the throttle to the floor, does it go away for a bit?)
CJ
PostPosted: Wed Mar 11, 2009 7:50 pm
I assume I am running a stock 1945 holley. Temp seems just fine, although when it is cold (-0 and lower) it has a tendency to do it more often.
PostPosted: Thu Mar 12, 2009 6:16 am
Is this Detonation? Or Pinging? I had this problem when I went to a super six on my 87. I bought a NOS carb from Dan and it fixed the problem.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Mar 12, 2009 6:59 am
Could it be the sticky lifter not completely unsticking just sort of doing its job?
and Cuda, how did the super six improve your 87?
PostPosted: Thu Mar 12, 2009 7:42 am
Is this '86 Lean Burn equipped? Does it have a regular #1945 or a feedback #6145 (with oxygen sensor in the exhaust manifold collector)?
PostPosted: Thu Mar 12, 2009 8:10 am
Per the FSM, looks like it is NOT the feedback, definitely a 1945.
Imagehttp://photos-d.ak.fbcdn.net/photos-ak-snc1/v2681/14/54/1024195730/n1024195730_30349235_2777425.jpg
PostPosted: Thu Mar 12, 2009 9:38 am
I'd swap out the coil-to-dist ignition wire; I've had ones that caused problems like that intermittently even though they tested OK at other times; then I'd swap coils if it has more than 100K miles.
PostPosted: Thu Mar 12, 2009 10:00 am
I'll give it a try and post if it helps.
 Post subject: chugging
PostPosted: Thu Mar 12, 2009 11:53 am
FYI- I had an intermittant hydraulic lifter type noise on my original engine that turned out to be a badly worn rocker arm.
PostPosted: Thu Mar 12, 2009 5:16 pm
15MPG over a Shot nonfunctional Lean Burn system...About 22 to 25 Mpg Hwy at 55. With the rear end in the truck anything over that and the mileage really drops.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Mar 13, 2009 7:49 am
66acuda-
auto or 4 spd?
PostPosted: Fri Mar 13, 2009 7:54 am
904 Auto not the 727
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
