It is currently Sun Nov 22, 2026 11:46 am
PostPosted: Fri Mar 13, 2009 6:48 pm
My 74 Dart Sport steering wheel was factory black. There was a slight crack at the 12:00 position, so I took some JB Weld and filled in the crack. After sanding it down, it looks good but the JB Weld is gray. What kind of black paint should I use to spray the gray to the original black? Is is a flat, gloss, etc?
PostPosted: Fri Mar 13, 2009 7:43 pm
Going to be very difficult to get a patch/match job that'll be invisible after the paint dries — you're probably going to want to clean, prime, and shoot the entire wheel so it winds up all one colour, and all one finish. I'd recommend a semi-flat (semi-gloss, satin) black paint. Painting plastic is very different than painting metal or wood, and it's harder to get good adhesion. See my armrest post.
PostPosted: Fri Mar 13, 2009 8:09 pm
I used a plastic etching primer for mine (after serious repair surgery and smoothing) They recommend that you apply your top coat while the etcher is still tacky. I did a base coat, metal flake in clear and a bunch of clear to follow. So far it still looks great with no cracks but it's less than a year old so time may tell. I'm also really careful to have no ring contact.
PostPosted: Fri Mar 13, 2009 8:48 pm
I wonder how Krylon Fusion would stand up to steering wheel use? I used it on my defroster vents with good results, but those have no contact, sweat, et cetera to wear them. Just a lot of sunlight.
PostPosted: Sat Mar 14, 2009 6:17 am
Hey SV
How long ago? Just wondering about that hot Texas sun...Its like here.
Thanks,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Mar 16, 2009 1:39 pm
I couldn't track down exactly when I painted the vents, but I think it's been at least three years. If it does fade, refurbishment is a spraycan away. The color is a satin burgundy, which looks OK with the red interior.
BTW, the vents were from a '66 Valiant, and were blue IIRC. The vanes in mine had long since turned to dust. A little scrubbing with a green Scotchbrite pad cleaned up the newer vents and prepped them for paint.
