It is currently Wed Oct 14, 2026 3:36 pm
Post new topic  Reply to topic  [ 59 posts ]  Go to page Previous 1 2 3 4
PostPosted: Tue Mar 17, 2009 7:56 am
Car Model: 1968 Plymouth Valiant 100
also make sure you and anyone who tried to take a wheel off the lugs of the left of the car turn right to loosen them the ones of the right turn left
Ah yeah, been there and done that. A friend of mine that I work with told me about that after I had busted a handful of bolts off. I thought they were just too rusty. :oops:
And yeah I agree with Cuda on the cinderblock thing, the guys from my work warned me about them collapsing. I have my car on a patch of asphalt but my jackstands sunk through it so I had to place thick wood planks under them. I bought my stands from harbor freight for cheap by the way.
A word of advice from my 'live and learn' file, becareful using one of those jacks with wheels on dirt. They are meant for use on a hard flat surface. On dirt they sink which stops it from rolling which pushes the car. -Dan
PostPosted: Tue Mar 17, 2009 8:19 am
Alright went to the radiator shop. Asked the guy, he said $55 to clean and repair it. Maybe it's just me, or does that seem a little too cheap?
Maybe the radiator isn't in that bad of shape. Also the guy might be one of the honest old school guys that charges a fair price for a job. You can always get a 2nd estimate.
Thanks Mike
PostPosted: Tue Mar 17, 2009 2:55 pm
Made a deal with my mom, she's going to pay to get the radiator fixed up next Friday if the bracket comes by then.
Once I get the car running, I'd like to get it set up to do decent gas mileage. Any ways to go about doing that?
PostPosted: Tue Mar 17, 2009 3:21 pm
Do a search as there is a lot of information about that already on here. The search button is your friend LOL
Thanks Mike
 Post subject: other stuff
PostPosted: Tue Mar 17, 2009 3:34 pm
If you don't know how well the car's been maintained, some basic first things are: air filter, fuel filter, oil change, chassis lube, transmission oil/filter. I think someone mentioned valve adjustment. Enjoy the journey and the destination.
PostPosted: Tue Mar 17, 2009 8:52 pm
What's nice about the slant six is that the best mileage is to be had basically by making it stock. Stock, but well maintained. As I think of it, there's only two places to look for more mileage basically - ignition and the carb. At some point down the road, you'll chunk up $100-200 for the electronic ignition and that will pretty much be that as far as mileage is concerned. At another point, you'll rebuild or replace the carb and that will be that.
I would expect around 18 city and low 20s highway. Funny - that's more than comparable to a modern midsized car, with stellar cost of ownership by comparison.
Kip-On-Truckin'
1965 Valiant wagon Turbo slant (work in progress)
2000 Chevy 155" cargo van - The Abductor
1970 Newport convertible
1996 Buick Roadmaster Wagon
1966 CruiseAire motor home
1990 Toyota 1 ton box truck TURBO slant (scraped)
PostPosted: Wed Mar 18, 2009 5:03 am
Actually you can gain some power and mileage, by milling the head to get about 9:1 compression. However that requires more money and labor. Along with a compression increase, a mild cam can also help both, but you need to balance the compression, cam, gear ratio, and type of driving.
PostPosted: Wed Mar 18, 2009 4:54 pm
Think I figured out where the later engine (and mishmash of parts came from): On the left of the rear bumper is "Darlington Technical College".
Also found a road flare from 1963 wedged under one of the supports.
 Post subject: concrete blocks
PostPosted: Tue Nov 17, 2009 6:23 pm
NEVER, I REPEAT NEVER USE MASONRY BLOCKS TO SUPPORT A LOAD WHILE YOU ARE UNDER IT!!!!!!!!!!! masonry was designed to be set in mortar so the load would be evenly distributed. if you just shove them under the car and slap a board on top, you are courting disaster. if there is a small bump on the ground, a rock or any other point load the block could shatter, and if you are under that car, it can crush you to death, or trap you, unable to breath. I was lucky someone came out looking for me!
Dave
1972 d-100 parts truck
 Post subject: Re: concrete blocks
PostPosted: Wed Nov 18, 2009 5:09 pm
yea also never use jack stands on wet ground my duster almost killed me that way (and bent my jack stand!)
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Wed Nov 18, 2009 6:29 pm
I guess I shouldn't talk about the time I swapped a rear axle in a Dart supporting the rear end with two bumper jacks...
PostPosted: Thu Nov 19, 2009 4:29 pm
:shock: You get the "dangerous repair award" Congratulations... err... perhaps not :lol:
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Thu Nov 19, 2009 4:51 pm
Yeah, it literally fell off the bumper jack as I tightened down the last lug nut. I had to scoot out of the way to avoid being crushed.
PostPosted: Fri Nov 20, 2009 4:09 am
congrats you are alive
Users browsing this forum: Amazon [Bot], Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 8 guests
