It is currently Sat May 02, 2026 10:48 pm
Post new topic  Reply to topic  [ 69 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: Turbo header started
PostPosted: Thu Mar 05, 2009 2:28 pm
3.5" down pipe and 3x2x1.
Moving slow but progress is being made.
Need to measure the rod bearings and then I can give a final crank pin diameter. The block is ready for the machine shop as well.
[url]<a href="http://www.flickr.com/photos/18510442@N02/3326218257/" title="144_4414 by dts223, on Flickr"><img src="http://farm4.static.flickr.com/3577/3326218257_ca2a099095_b.jpg" width="1024" height="768" alt="144_4414" /></a>[/url]
PostPosted: Thu Mar 05, 2009 3:07 pm
Cool! Keep us posted.
PostPosted: Thu Mar 05, 2009 7:23 pm
MMMMMMMMMMMMMMMMMMMMMMM.......................................header porn. :D :D :D :D
 Post subject: turbo
PostPosted: Fri Mar 06, 2009 4:31 am
Nice!! what turbo are you running?
Nick
86 d150 turbo /6.
PostPosted: Fri Mar 06, 2009 4:45 am
Looks like someone is getting serious. Awesome!
PostPosted: Fri Mar 06, 2009 6:07 am
The turbo is a PTE6262 DBB .63ar on the exhaust. It is a Grand National based turbo. It is supposed to be capable of 670hp.
PostPosted: Fri Mar 06, 2009 12:45 pm
What kind of steel are you using tom??
Stainless or just more Regular Thick Pipe stuff?
Is that the same turbo as when I went for a ride in your sleeper MAchine?
keep up the good work!
PostPosted: Fri Mar 06, 2009 2:04 pm
This a different turbo than when you were in the car. Way bigger on the compressor side. Exhaust turbine is bigger but the AR is the same.
It is just mild steel. 16ga & 18ga pipes.
Tom
PostPosted: Mon Mar 09, 2009 10:27 am
Looks good Tom. I'm assuming your running an internal wastegate? I got some pics of the turbo setup on my dads Dart I should show you. It's going to be a 318ci though. I finished up the exhaust a few days ago.
It looks like you may beat me this year. I may have to do something this winter to fix that. Later
PostPosted: Mon Mar 09, 2009 7:22 pm
Cool Ryan, post some pics of those headers...if not here then on turbo mustangs.
Yes, it is still an internal wastegate. I have one of the 6 pipes done. It will be hard to beat your ET because I still plan on running the skinny tires. I hope it MPH's like a SOB. I'm hoping for 120+.
You go man, I hope to give you something to shoot for this winter.
 Post subject: Header "Porn"
PostPosted: Wed Mar 11, 2009 3:20 pm
[url]<a href="http://www.flickr.com/photos/18510442@N02/3347084681/" title="144_4439 by dts223, on Flickr"><img src="http://farm4.static.flickr.com/3599/3347084681_d39ba5593c_b.jpg" width="1024" height="768" alt="144_4439" /></a>[/url]
PostPosted: Wed Mar 11, 2009 3:22 pm
More Porn
[url]<a href="http://www.flickr.com/photos/18510442@N02/3347085251/" title="144_4440 by dts223, on Flickr"><img src="http://farm4.static.flickr.com/3459/3347085251_3546a85c2c_b.jpg" width="1024" height="768" alt="144_4440" /></a>[/url]
PostPosted: Thu Mar 19, 2009 4:39 pm
Just about done.
[url]<a href="http://www.flickr.com/photos/18510442@N02/3368443239/" title="Turbo Header by dts223, on Flickr"><img src="http://farm4.static.flickr.com/3627/3368443239_28f25a05e9_b.jpg" width="1024" height="768" alt="Turbo Header" /></a>[/url]
[url]<a href="http://www.flickr.com/photos/18510442@N02/3368443617/" title="Turbo Header with intake by dts223, on Flickr"><img src="http://farm4.static.flickr.com/3549/3368443617_ba226f3c38_b.jpg" width="1024" height="768" alt="Turbo Header with intake" /></a>[/url]
PostPosted: Thu Mar 19, 2009 4:49 pm
Looks GREAT man :D Makes me want to build a set of my own! You are the man for getting it done. I really like your build and have been following it closely for a while.I think you have made major accomplishments in the slant world. I mean 12.9 on little whitewall tires and 2.94 gears :twisted: brings a smile to my face every time I think about it . Wait till you get a reworked head and new cam,it will be a whole new beast.
PostPosted: Fri Mar 20, 2009 4:22 am
Thanks Gent. A learning process for sure. Started with the back 3 and learned a few things and the front 3 came out much better.
