It is currently Fri Dec 26, 2025 6:16 am
 Post subject: Torsion bars
PostPosted: Sat Mar 21, 2009 8:25 pm
Going to pick up a set of 892/893 torsion bars tomorrow. Should be a direct swap for the old ones yes? Or is there a gotcha? They are year/model appropriate.
Thanks in advance,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Sat Mar 21, 2009 8:28 pm
Yep, all A-body torsion bars are interchangeable. Make sure to put the left bar on the left, and the right bar on the right.
PostPosted: Sat Mar 21, 2009 8:29 pm
Ok, is the odd number for the port or starboard side?
PostPosted: Sat Mar 21, 2009 8:49 pm
With paired parts on a Mopar, the even-number part goes on the starboard side, the odd number to port.
PostPosted: Sun Mar 22, 2009 10:29 am
Aye, matey! And fore and aft make no difference.
Unless you want to leave some possibility of seeing the number through the rear socket ...
