It is currently Sat Jun 20, 2026 11:08 pm
PostPosted: Sun Mar 22, 2009 1:45 pm
I've owned my 1969 Dart for about 10 years and it's always had a little shimmy in the steering wheel at highway speed (70 mph). Could this be a worn out manual steering box or should I be looking somewhere else? Is it possible to adjust the steering box? :?
EARL
PostPosted: Sun Mar 22, 2009 1:55 pm
Assuming you're not still on the same tires as ten years ago I'd look carefully at the wheels, axles and front hubs. I'd put the car on stands and break out my dial indicator, but that's just me.
PostPosted: Sun Mar 22, 2009 2:09 pm
There are in fact two adjustments to be made to the steering box, see here.
Shimmy at highway speeds can also be caused by out-of-round or out-of-balance tires and/or wheels, loose ball joints, or looseness in other steering and suspension components and bushings.
PostPosted: Sun Mar 22, 2009 3:43 pm
Check for any crud build up stuck to the inner side of the wheel. I have had dried mud and at times ice cause a tire imbalance. Once removed all is ok. A bent rim will sometimes cause a vibration, or shimmy, as well as a broken cord in the tire carcass which is harder to detect untill it gets real bad.
PostPosted: Sun Mar 22, 2009 4:47 pm
....and idler arm bushings.
You have to get it off the ground and move and shake everything. Shimmy is usually caused by some kinda slack.
When was the last time it was on a hoist?
PostPosted: Sun Mar 22, 2009 5:09 pm
What Sandy said, idler arm bushing or pitman arm bushing possibly.
Have a helper turn the steering wheel back and forth while looking at all the linkage keeping an eye out for any suspect play.
PostPosted: Sun Mar 22, 2009 6:52 pm
Thanks for all the good info. I'll check it out tomorrow. :)
EARL
