It is currently Mon Jun 15, 2026 1:56 pm
 Post subject: 1 BBL gaskets?
PostPosted: Mon Mar 23, 2009 11:04 am
4 stores, zero gaskets! Can't order the gasket that goes between the air cleaner and the carb.
Even NAPA!
PostPosted: Mon Mar 23, 2009 6:52 pm
If all you need is the gasket for between the carb and air cleaner, I would use a heavy, thick gauge paper. I use "blotters" at work on grind wheels and happened across some w/ the right Inner Dia. I just trimmed the Outside Dia. to fit, for the side screw clamp style air filter on the old stromberg 2 bbls. This style needs them. They are just thick paper, kinda like the thin paper boxes for a deck of cards, not so much like weak construction paper though.
I don't know what you running, but I don't use one at all on my 77 1bbl holley with a stock air cleaner unit.
for profiles and pictures of my mopars--> http://www.fquick.com/dietz_diggler
PostPosted: Mon Mar 23, 2009 8:00 pm
74 1bbl Holley
 Post subject: gaskets
PostPosted: Mon Mar 23, 2009 8:06 pm
I,ll try my NAPA store and try to get a PN for you.
PostPosted: Tue Mar 24, 2009 8:29 am
I aquired several generic rubber o-rings from my local Ace Hardware, can't recall there exact purpose in life (garbage disposal?) works just fine.
Dave
PostPosted: Tue Mar 24, 2009 8:34 am
Hey I work at Lowes! Maybe I can find them.
PostPosted: Tue Mar 24, 2009 8:51 am
I'm positive their intended for a garbage disposal :shock: , odd, my brain must have been in synch that day otherwise I would have walked right by them without a second thought :lol:
Dave
PostPosted: Tue Mar 24, 2009 9:23 am
I've used a gasket from a used oil filter before. A little loose and dosn't last that long, but works in a pinch.
PostPosted: Tue Mar 24, 2009 2:10 pm
Been using Purolator red rubber ring will look good in the engine compartment! :lol:
Got a fresh one that only went 150miles :( :shock:
PostPosted: Tue Mar 24, 2009 2:53 pm
My ad hoc o-ring must be around 6 years old, shows no signs of failing, I suspect it is silicone based.
Dave
Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
