It is currently Fri May 22, 2026 6:58 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Mon Mar 23, 2009 3:03 pm
No strap kits in stock, I got a whole new u-joint. I am going to use the strap kit that was on the original Mopar U-Joint. I didn't look to closely at the caps on the rear u-joint because I have never heard of something like this happening. I thought the rear axle yoke held those things on securely?
PostPosted: Mon Mar 23, 2009 3:27 pm
You must put the C-clips on all the U-joint caps otherwise you can toss the cap. Some rear end yokes have tabs that keep the caps in place, but not ones that Chrysler used.
PostPosted: Mon Mar 23, 2009 3:51 pm
Ohhhhhhh...... :oops: Image
PostPosted: Tue Mar 24, 2009 7:24 pm
Reed, I did that same thing years ago on a '74 Dodge Dart. :oops: :oops: :oops:
Later,
'78 Volare 225
'67 Charger 318
PostPosted: Tue Mar 24, 2009 7:36 pm
I'll tell you one thing, I'm only making that mistake once. :oops:
