It is currently Mon Jun 01, 2026 6:56 pm
PostPosted: Mon Mar 23, 2009 3:45 pm
Dan, coming from the air breather.....all the dirt and sand that gets blow over the engine and collects on top of the valve cover is unbelievable. I sure don't want that being sucked into the engine.
What you're seeing is not coming out of the crankcase breather. It is ambient dirt blown around by normal movement of the car through dusty air...sticking to the oil film that does come from the breather and deposit on the valve cover.
I want clean filtered air coming into the crank case, not dirt, dust a road grime
Factory-type ducted crankcase breather is the best way to achieve that.
PostPosted: Mon Mar 23, 2009 6:13 pm
What does the water separator cost? Is its only purpose for removing water or is it also a fuel filter?
PostPosted: Mon Mar 23, 2009 9:27 pm
Bren,
Yes, it is a fuel filter and water separator Perma-Cool #81794 $39.88. This is one of the first options for equipment on gas inboard/outboards from 18' on up. Filters down to a 2 micron level.
This is the Summit link: http://store.summitracing.com/partdetai ... toview=sku
For more info: http://perma-cool.com/Catalog/Cat_page26.html
PostPosted: Mon Mar 23, 2009 9:34 pm
Dan,
There is no oil film on the valve cover, just lots of dust, sand and debris... I just don't want any of that getting inside the engine through the air breather.
PostPosted: Tue Mar 24, 2009 5:56 pm
This will very soon be a really dumb argument to have, if it hasn't already reached that point.
Think about it for 30 seconds: tens of millions of Chrysler (and every-other-make) cars have been equipped with ducted crankcase breathers going to the dirty side of the air cleaner housing. Every single Chrysler product since 1968. You don't seriously, really think they're all full of this sand and crud you imagine to be coming out of (or going into) the crankcase...do you?
PostPosted: Tue Mar 24, 2009 6:04 pm
.......mebbe
PostPosted: Thu Mar 26, 2009 6:25 pm
A poor solution doesn't make it right.
Users browsing this forum: Google [Bot], Mike'68Dart and 4 guests
