It is currently Wed May 20, 2026 10:00 am
 Post subject: rear end filler plug
PostPosted: Tue Mar 24, 2009 8:09 pm
could any one tell me type of tool needed to remove the rear end cover filler plug. not sure of the rearend size but it is in a 76 scamp,225 auto. rear drums 10'' with a 4 inch bolt pattern. it looks like a cross between an allen and star.
thanks
jd
PostPosted: Tue Mar 24, 2009 8:10 pm
It's 1/2" double square on the 7 1/4. A 1/2" ratchet or extension will fit fine.
PostPosted: Tue Mar 24, 2009 8:12 pm
And if you don't have (and don't want to buy) any ½"-drive tools, just pick up a 3" length of ½" square bar stock at the hardware store. It'll fit right in the plug, and you can turn it with an ordinary ½" wrench.
PostPosted: Tue Mar 24, 2009 8:14 pm
thanks, i can finally get the lube changed this weekend.
thanks
jd
