It is currently Mon Jun 15, 2026 4:05 am
 Post subject: radiator
PostPosted: Thu Mar 26, 2009 5:46 am
I have a 87 Dodge Ram /6, 225, auto, The radiator is leaking from the bottom. Can this be JB welded? If not, What other radiators are interchangeable? I heard some Ford's maybe Jeep. Thanks
PostPosted: Thu Mar 26, 2009 6:04 am
You can have it tested at the radiator shop. I have a V8 radiator in the Dart. Just had to use a flex hose. Don't ask where it came from! It was in it when I bought it.
PostPosted: Thu Mar 26, 2009 6:29 am
Last spring, I had a leak in the bottom of my Volare's radiator. I tried JB Weld, but it didn't work. Maybe if I had taken the radiator out first...
Anyway, I just used a bottle of leak repair from Bar's. It fixed it right away.
The rad in my Volare is out of a Volare station wagon that had a 318. Being that you have a pickup, you probably have room for a bigger rad.
'78 Volare 225
'67 Charger 318
PostPosted: Thu Mar 26, 2009 10:42 am
take it out clean around leak get some plumbing solder and flux ,a propane torch....solder it ...not that hard of a job
ol'school roddin'
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
