It is currently Fri Dec 26, 2025 6:16 am
 Post subject: Shock Replacement
PostPosted: Fri Mar 27, 2009 8:58 pm
Im replacing the front shocks on my dart, ive never replaced a shock myself and have questions.
How do you keep the entire top half of the shock from spinning? Where the Shock is bolted to the fender.
Ive tried having 2 wrenches, one hanging onto the bolt and one on the nut, but seems like an impossible task to get the bolt off. I cant keep the top half of the shock from spinning with the bolt.
Probably something simple im not doing, right? lol
Any tips?
PostPosted: Fri Mar 27, 2009 9:22 pm
Wrap a hand or a strap wrench around the body of the upper shock and hold it while you turn the wrench on the nut. Alternatively, I have been able to put a 1/4 inch wrench on the flat spots on the tops of shocks to hold them from spinning while I use another wrench to turn the nut.
PostPosted: Fri Mar 27, 2009 9:50 pm
You've got the right idea, tho your shock absorber's central stud may be rounded off. Grab and hold it good and tight with a Vise-Grip.
PostPosted: Fri Mar 27, 2009 11:33 pm
An impact wrench can usually spin the nut faster than the shaft, so you can get the nut off.
Do it in bursts..........
PostPosted: Sun Mar 29, 2009 6:36 pm
Thanks.
Used Reeds advise and worked perfect.
it was stripped, but I still got the 1/4 wrench to work.
