It is currently Fri Jun 05, 2026 9:55 am
 Post subject: Locked keys in my duster
PostPosted: Sat Mar 28, 2009 2:39 pm
This is embarrasing. I locked my keys in my Duster. Is there anyway I can unlock the door without calling a locksmith?
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Sat Mar 28, 2009 3:00 pm
Find a Slim Jim, it should work, but be gentle or you will be pulling door panels to reconnect lock linkage...
Insert it near the interior lock pop up button. Patiently fish around until the lock button starts to move, and slowly & gently lift up.
Get a second key made to keep in your wallet.
PostPosted: Sat Mar 28, 2009 3:02 pm
There are several ways. The fastest requires a claw hammer.
If you have patience and dont mind wrecking the door glass rubber there is the coathanger trick....
PostPosted: Sat Mar 28, 2009 3:08 pm
Back in the old days when I had a Challenger and a girlfriend who was from Kentucky, I saw a coat hanger in the backseat. I asked Ginny what it was for and she told me she had locked the keys in the car at work and kept the hanger in case she did it again. :shock:
PostPosted: Sat Mar 28, 2009 3:26 pm
I once was walking through a parking lot when a guy sitting inside a soft top Jeep yelled at me to help him out because he had locked himself inside his car. I'm not joking.
PostPosted: Sat Mar 28, 2009 4:01 pm
Was she a blonde?
PostPosted: Sat Mar 28, 2009 4:29 pm
The door glass won't necessarily be wrecked; only if you're careless. You have an advantage here because you're working with the frameless door glass of a Duster, but even with full-frame door glass it can be done. I locked my keys in my '89 D100 in a parking lot in Michigan last year, very very far from home. Couldn't get a coathanger wire between the door and the doorframe, but I found I could sneak it between the top of the (very very very slightly rolled down just by vibration) glass and the doorframe. Think thru the angles you'll have to work thru to get enough wire on the inside of the glass, then bend the wire accordingly. Put a "V" bend in the very end with which to snag the door lock knob. The primary tool at work here is patience. The coathanger wire is secondary.
PostPosted: Sat Mar 28, 2009 4:40 pm
It took me longer to get a hanger than it took to break into my 71 Swinger
PostPosted: Sat Mar 28, 2009 7:09 pm
In 1975 in Baja I found out the kids could break into my 1951 DeSoto faster than I could open it using keys. I quit locking the car.
PostPosted: Sat Mar 28, 2009 8:40 pm
Was she a blonde?
No, hillbilly. :lol:
PostPosted: Sun Mar 29, 2009 8:05 am
Slantzilla,
Most of the Hillbillys around here are fairly smart,its the recent influx of city folks that lack intelligence. :shock:
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Sun Mar 29, 2009 10:29 am
Slantzilla,
HyperValiant
:lol: :lol: :lol: :lol: :lol:
One thing is for sure, it was not her intelligence that attracted me in the first place. :lol: :lol: :lol: :lol: :lol:
 Post subject: Hmm...
PostPosted: Sun Mar 29, 2009 12:00 pm
Er, was it the C-body sure grip 8 3/4" rear axle? :lol: :lol:
:wink:
PostPosted: Sun Mar 29, 2009 2:28 pm
Where should the thing that I pull up on with the hanger be located? Under the lock? If so how far down?
Ronnie
PostPosted: Mon Mar 30, 2009 4:26 pm
You may have two options:
If your door lock "push-pull" rods (the thing one pushes to lock the door) have a head on them hook it with a "V" shaped bend and pull up.
If the push-pull rods are headless you will have to fish around in the door with the wire shaped like an "L" with an inch long leg. If you make a little wedge from wood, you can stick the wedge between the glass & door sill to free up a little working room to maneuver the wire in the door. Be genital, it won't take any more force than what you need to operate the push-pull rods. All the linkage is located from under the push-pull rod and over to the latch in the door jamb. You may be able to use a little "Mini Mag" flashlight light once the wedge is in place to see some of the linkage.
An other trick is to bend a "J" shape in the wire, and come up under the push-pull rod where it screws onto the linkage. Catch the end of the wire between the threaded rod and the push-pull knob and gently pull up.
