It is currently Fri Nov 20, 2026 12:01 am
 Post subject: temp. gauge ?
PostPosted: Sun Mar 29, 2009 11:00 am
It might be normal, but I have never noticed.
I try to let my engine run a little every now and then , but I never went back to crank it up a few minutes afterward. I did today , and when I cranked it up , the temp gauge was pegged at hot, but I came down gradually. I take it that it is because ,when I shut off the engine , there is nothing moving around anymore and just heats up eveything.
This is probably a stoopid question, but... Is that normal?
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Sun Mar 29, 2009 11:12 am
Yup, that's exactly what's going on. Engine stays hot after shutdown, but coolant no longer circulates, so the hottest coolant rises to the top of the system where the temp gauge sender is. As soon as you start the engine, you can see the temp begin to drop as coolant starts circulating again.
PostPosted: Sun Mar 29, 2009 11:16 am
Thanks Dan,
That is what I thought , I just hate noticing things I have never noticed before :D
Dave
81 Dodge D150
Users browsing this forum: Google [Bot] and 9 guests
