It is currently Tue Nov 17, 2026 11:01 am
 Post subject: Fuel Mileage
PostPosted: Wed Apr 08, 2009 6:44 am
I've got an 84 D-100 with the 225 Lean burn and I'm getting about 13 mpg! Should it be more? Also if I swap to HEI ignition would that help with power?
PostPosted: Wed Apr 08, 2009 6:59 am
I got about the same with my 87. I converted it to super six and EI and get 22.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Apr 08, 2009 7:06 am
Car Model: 1986 D100 /6 A833od shortbox
Mine gets 14 around town, 16 on the highway. I am following Cuda's lead and doing the super six switch asap.
PostPosted: Wed Apr 08, 2009 7:20 am
with my 100% stock 83 D-150 I have found the biggest impact on mpg is how I use the throttle. Keep it under 65 on the highway,, don't use the throttle like on on-off switch in stop and go driving and I'll get 18 mpg easy.
will be interesting to see what happens after the motor improvements are made
PostPosted: Wed Apr 08, 2009 7:49 am
Buy a vacuum gauge and stay in the "green"
