It is currently Thu Dec 25, 2025 8:48 pm
PostPosted: Wed Apr 08, 2009 5:10 pm
Work in progress.
225 slant 6. No engine mods
Current list of stuff Ive put into it/done to it:
Edelbrock air cleaner
rebuilt carb
new front rotors/pads/hub
electric fuel pump
new fuel lines
new spark plugs
new distributer/cap/rotor
new master cylinder
new brake lines
new rear drums/shoes
new coil
repaired sending unit
new valve cover gasket
Removed smog pump, welded plug in exhaust
Removed charcol canaster
Hollowed cat converter
Plan to do:
oil frame
2" lift kit
dual exhaust
engine overhaul including pistons, rings. Probably bore engine out. Maybe a stroker kit
New timing chain
New camshaft
HEI conversion
Bucket seat conversion
4 Spd. manual conversion
New Electric Fuel Pump
Brazed two new lines in my sending unit. Tried to get a pic but couldnt get camera high enough. You get the idea though :)
Added foglights out of an 88 chevy winabego van when we pulled the engine. installed a switchboard from it too with two inline resetable fuses.
-- Mister Perkins --
Pictures of my truck
http://www.cardomain.com/ride/3257131p
Last edited by Mister_Perkins on Sat Apr 25, 2009 3:29 pm, edited 1 time in total.
PostPosted: Thu Apr 09, 2009 3:25 am
Very Cool going to be an awesome ride! I love trucks!!
1956 Dodge D100 Pick up
power plant 225 slant six
