It is currently Fri Jun 19, 2026 3:15 am
 Post subject: hard to start up
PostPosted: Tue Apr 14, 2009 8:20 am
hey guy it has been a while but my car is having hard time starting it will start but shortly after it will die it takes about three time before it it will stay alive is there anyway i could fix it since this car is now my daily drive i also need to fix the blower motor which it is not working thanks for the help
PostPosted: Tue Apr 14, 2009 9:33 am
Is this with the car cold (after sitting all night or all day), or when it's warm (after running into the grocery store for a few items) or both?
Sounds like choke and/or carburetor issues. Carburetor operation and repair manuals (and some training movies) are posted here for free download. If you're having cold-start issues, I recommend putting in one of the Electric choke kits. Tune-up parts and technique suggestions in this thread.
PostPosted: Tue Apr 14, 2009 11:37 am
did the blower motor ever work in your car? if not id check connections/wire routing to make sure everything is hooked up and were it belongs.
PostPosted: Tue Apr 14, 2009 11:58 am
yeah blower use to work. the car is hard to start when it is cold
PostPosted: Fri Apr 17, 2009 7:22 am
so i started my car up this morning the the blower motor is now working so i am guess something wrong with the wires
PostPosted: Fri Apr 17, 2009 8:31 am
After the car has been sitting for a while, sometimes there is corrosion in the bulkhead connector. If you have an old car, maybe you can have somebody hold the connector steady with a small screwdriver from under the hood, and push on the firewall connector under the dash with another small screwdriver, and try to push the connector together. It doesn't cost anything to try, anyway. Disconnect the battery negative cable first.
