It is currently Fri Nov 20, 2026 10:14 am
PostPosted: Tue Apr 15, 2003 6:17 pm
In my '72 Duster I have a bit of a problem. Over mild bumps the front end of my car kinda does a little dance down the road and going across pavement changes or certain dips in the road the car wants to go left..hard left. I have to compensate for this while driving by turning the steering wheel almost 90 degrees just to keep the car on the road. when i apply the brakes it'll straighten sligtly but it seems that going around a slow turn will temporarily solve the problem. I've already replaced upper and lower ball joints along with inner and outter tie rod ends. one of my mopar friends said it could be the strut rod bushings...the look mildly dry-rotted but i don't see that causing such a big problem....PLEASE HELP!
-Don
Forget the flowmasters...here come the good ol' GLASSPACKS!!!
PostPosted: Tue Apr 15, 2003 6:35 pm
I had the same kind of problem with my 65 Valiant. The person that owned it before had the front end setup to high. I just lowered the front end down a few inches and it helped. A lot of people set the front end on mopars to high. Don't know if this will help you but its not hard to try with torsion bars.
PostPosted: Tue Apr 15, 2003 6:39 pm
Sounds to me like the steering box is worn out. :shock:
PostPosted: Tue Apr 15, 2003 11:53 pm
A loose idler or pitman arm will also do this.
Once I had a strut rod break, the car would pull big time, especially on braking. It took a while before I was able to figure it out, everything looked normal when the car was just sitting there. The strut rod had broke right behind the rear of the bushing asembly and was butted together most of the time.
PostPosted: Wed Apr 16, 2003 8:39 am
Well guys, thanks for the responses, it helps give me a good idea of what I need to do. I'm gonna start throwin parts at it as soon as money permits.
Thanks again,
-Don
