It is currently Wed May 20, 2026 1:19 am
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Fri Apr 17, 2009 9:20 am
is there a chart to use to know how much to shim ? and how much spring pressure is just right ?
-Mike
PostPosted: Fri Apr 17, 2009 11:13 am
I measured them at a machine shop to find out what the seat pressure was at my installed height. Then I did, 030,060,090" to see what the pressure was. My buddy also has a formula from one of the mopar book and confirmed the numbers (if we didn't have access to a machine shop.) I will ask him where the formula is located.
PostPosted: Fri Apr 17, 2009 7:28 pm
thanks shaker, I know the info will be not only appreciated by myself but others as well. I can't wait till this build is done, oh and a little OT but I got my turbo today, wife sent pics, its beautiful.
-Mike
PostPosted: Fri Apr 17, 2009 8:14 pm
Need to redo trans lines and put in drive shaft. Everything else is mostly set. Waiting for the intake to be powder coated. It was supposed to be done last week!
Chrome isn't perfect and I didn't pay for it to be perfect. Wanted the durability.
[url]<a href="http://www.flickr.com/photos/18510442@N02/3451069401/" title="Header by dts223, on Flickr"><img src="http://farm4.static.flickr.com/3309/3451069401_9e3f958727_b.jpg" width="1024" height="768" alt="Header" /></a>[/url]
PostPosted: Sat Apr 18, 2009 1:19 am
That's Schweeeet! :D
PostPosted: Sat Apr 18, 2009 6:41 am
Wow, I need my shades, blink blink. If it dosent go good (and I'm sure it will) you can just sit at the curb with your hood open and draw a crowd. Cool.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Sat Apr 18, 2009 8:12 am
I dropped the crank off yesterday to be cut. I premeasured everything to give a final dimension for all of the journals. Since there are inconsistencies in bearings and crush it is a good idea to do this in advance. If they had taken a straight .010 off of the mains, my clearances would have ranged from .0022" to .0032". Most shops have a book that tells them the high and low limits to be within. Look at main #1 and the thrust#3. There is .001" difference. The line and main saddles were checked on this block and were straight and round respectively.
I also asked to have a groove cut in each of the mains to simulate a full groove bearing since those bearing sets are not available for a slant 6.
*********Bearing***Desired*****Crank
Main*****Measure**Clearance****Final*****Tolerance
1********2.7432****0.0023****2.7409****+/-.0002
2********2.7426****0.0023****2.7403****+/-.0002
3(T)******2.7422****0.0023****2.7399****+/-.0002
4********2.7431****0.0023****2.7408****+/-.0002
The rods were measured as well and a final dimension was given to keep the rod clearances between .0018" and .0022"
PostPosted: Sat Apr 18, 2009 10:35 am
just beautiful shaker, for the oil feed line are you just "T'ing" into the oil sender on the back of the OP for oil feed to the turbo ? And how are you running your drain back tube ?
-Mike
PostPosted: Sat Apr 18, 2009 12:18 pm
Mike,
I did "T" off of the oil pump for the turbo lubrication. For the return line, I welded a bung into the oil pan (above the oil level).
Tom
PostPosted: Sun Apr 19, 2009 7:33 pm
Mike,
Tom
Same here.
Looks good shaker. You gunna dyno it first or just run it?
The plan is next Sunday to get mine dynoed. Got the bars in today and all I have left are the seat belts and front shocks to install. Didn't make it to the track today. Later Tom
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Sun Apr 19, 2009 7:37 pm
I'm liking your 3 1/2" downpipe. How far are you going back. I may have to change mine.
PostPosted: Mon Apr 20, 2009 6:18 am
Everything but the tailpipe is 3 1/2. I bought a 3" tailpipe from TTI since 3.5 was not available.
If I get the time, I'd like to take it to the track first.
Tom
PostPosted: Mon Apr 20, 2009 2:14 pm
What did that chrome plating run you if you dont mind me asking??
PostPosted: Mon Apr 20, 2009 3:06 pm
It is no where near show quality, remember i wanted the durability. They nickle plated everything first. $150
PostPosted: Mon Apr 20, 2009 5:04 pm
Shaker,
your losing the sleeper look at least under the hood, are you going to try to keep the outer sleeper apperance? Got any of your first gen stuff you want to sell ie. turbo & pipes?
good job
Joe
70 Valiant 225,super six
65 Dart More Door race car 225/4bbl 8 3/4 3:91
70 Dodge D100 Sweptline short box 225/4spd
