It is currently Thu Dec 25, 2025 10:47 pm
 Post subject: Moog ofset bushes
PostPosted: Sat Apr 18, 2009 12:12 pm
Hi Gents - does anyone have the measurement of how far the moog upper control armbushes is of center? in mm/inches
Please :D
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Sat Apr 18, 2009 2:25 pm
I don't have exact measurement, however the center line of the bolt hole is about 1/3 of the diameter. You can pick up about 3 to 4 degrees of caster with them.
I installed a set last spring. Still need more caster, so I shall be purchasing a set of tubular upper control arms sometime.
PostPosted: Tue Apr 21, 2009 6:45 am
I'd say it's 3-5 mm off center. Yes, you get about 2-4 deg more +caster than stock. I run mine at +3 or 4 caster and -1 camber.
PostPosted: Mon Apr 27, 2009 1:34 am
Thx
We have a crowd over here that started making replacement bushes
Lathe turned metal pieces - cast in RUBBER R600 per set of 4 ~ $80 offset slightly more expensive
COOOL
Regards,
Fanie Gerber
PostPosted: Thu Apr 30, 2009 5:01 am
I did a quick measurement on my MOOG offset bushings. They are 3 mm off center, +/- about 0.5 mm error.
