It is currently Tue Nov 24, 2026 5:59 am
PostPosted: Sat Apr 18, 2009 2:56 pm
Well I've been working feverishly on the duster this week. Took it in and got the exhaust system done. Went with dual 2" pipes all the way back in stainless. Then got everything hooked up and started for the first time. Only had a few minor issues and it now runs. It still needs the carb tuned a bit and timing dialed in, it's about 6 degrees right now.
The exhaust is running though Thrush welded mufflers. Sounds not too bad but needs some adjustment. The right side sounds a bit different than the left. I think there is a small leak right behind the right muffler. Here is a link to a video of it. Last to do is set up the front end and a test drive by my mechanic. He said he should be able to get the alignment pretty close, but next stop will be the alignment shop and to see if I can get the A/C working
http://www.youtube.com/watch?v=VUrkN8eX7zE
Let me know what you think
Arizona Duster in Canada
PostPosted: Sat Apr 18, 2009 7:08 pm
Site Admin
Sounds good! :D
CJ
Users browsing this forum: Amazon [Bot] and 3 guests
