It is currently Wed Jul 15, 2026 1:45 pm
PostPosted: Sat Apr 12, 2003 1:25 pm
Is anyone aware of a coating that can be used to seal the inside of water jackets? Seems to me this would reduce rust formation and eliminate perosity issues while improving flow at reduced tempatures :?: .
PostPosted: Tue Apr 15, 2003 6:36 am
You might try Glyptal. It's used in electric motor shops as an insulator, and stands up to some pretty nasty conditions.
PostPosted: Tue Apr 15, 2003 10:03 pm
I was thinking about "sloshing"( a term used to coat aircraft wing tanks with epoxy) to strengthen a head I'm working on It's the third one I've ported and each time I seem to get a little more cocky, this ones got to be getting thin in places. What I'm worryed about is a possible insulating effect? causeing the head to get hotter? any body tryed this? and what material did you use? thanks Bruce J.
78b4ramSnortbed/6
PostPosted: Wed Apr 16, 2003 6:27 am
Glyptal helps with electrical insulation, but I'm not sure of its thermal insulation properties. Heat in electric motors is a big issue, of course. I have heard of some V8 engine builders using glyptal in the valley to help oil drainback. Just an idea!
Users browsing this forum: Amazon [Bot] and 1 guest
