It is currently Wed Jul 15, 2026 1:43 pm
PostPosted: Wed Apr 16, 2003 6:14 pm
the lights in my dash are starting to get a bit flaky again.. the left turn signal won't blink, and stays completely off. The right works fine. Same works for outside lights. It's not the flasher, when this happened before I replaced it and now same result.
Well, I'm pondering about a custom dash with autometer gauges perhaps. Has anyone done this before? Any thoughts/ideas? I think it might be a bit tough seeing as how there is an angle to the dash. Maybe I can use the frame of my original one and cut out the center to mount my own stuff in it.
PostPosted: Wed Apr 16, 2003 7:44 pm
Contributor
There is a guy over on the moparstyle.com forum that makes a custom dash for several Mopar models. I know he has them for the later A-bodies, but I'm not sure about earlier versions.
