It is currently Mon Nov 16, 2026 3:44 pm
Post new topic  Reply to topic  [ 41 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Apr 07, 2009 10:14 am
My Carb has an ESA signal tube. Will that work with the vacuum advance?
PostPosted: Tue Apr 07, 2009 10:16 am
Thanks. It helps a lot. Ive just got to get this thing better gas mileage (better than 13mpg) and ive got to get it to pass emissions and im sick of the lean burn.
Over the last couple years I have worked over my brother 1983 Dodge shorty van equipped with a 225 and originally equipped with lean burn to pass emissions and get 20-21 MPG on the highway.
Read all about it HERE
That thread gives the specs of what I did to the motor, the spark advance curve I wound up with, and other tricks I did to get a slant six powered van to get passable gas mileage.
PostPosted: Tue Apr 07, 2009 10:17 am
I would think it would be ok. If not NOS (new old stock) or good used carb can be had from members of this board.
Frank
PS where are you located? DUH We may have someone close who can help. Nope
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Apr 07, 2009 10:21 am
I'm in Utah about 20 minutes south of Salt Lake.
PostPosted: Tue Apr 07, 2009 10:26 am
No. That tube provides full manifold vacuum all the time. You need to get a vacuum guage and find a port on the carb that has no vacuum with the throttle closed, but full vacuum as soon as the throttle is opened.
PostPosted: Tue Apr 07, 2009 10:33 am
Yup
I figured hat out after all ready engaging my mouth. :oops:
I had put DUH and Nope on the edited version. :lol: :lol: :lol:
Im not sure who we have in Utah or where they are.
Read Reed's post by clicking it and look at what he has done. PM Duster Idiot aka Rob and also Slant Six Dan ask them your respective questions and give them a day to respond. In the mean time use the search function and look the site over. Also of interest is the Articles section on the home page.
Enjoy,
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Apr 07, 2009 10:36 am
Yup
Enjoy,
Frank
No worries Frank, we've all done that. :lol:
 Post subject: lean burn
PostPosted: Mon Apr 13, 2009 5:13 pm
I just got done doing a lean burn conversion. I have an 81 W150 I took the entire ignition system from a 76 dart and replaced it and it works
great. You will need wireing diagrams for yours and the other vehicle
though. If you need more help just ask.
PostPosted: Sat Apr 18, 2009 5:12 pm
I converted the 225 in my 84 D-100 a while back. I went to my Napa store and bought a distributor for a 73 Dodge pickup. I also bought a condensor and module for a 1980 GM 4 cylinder. I used a relay I had from another project. I also have a holley 1945 carb. I installed a manual choke and unhooked all the wires and it runs fine.
It's ugly, but it runs.
PostPosted: Thu Apr 23, 2009 5:31 am
Car Model: 87 B150, 1970 Valiant 4-door
Not so sure about that. My 1945 hooks up to my ESA via this thing (it's ported):
PostPosted: Thu Apr 23, 2009 8:43 am
Then I think someone has hooked your computer up wrong. The ESA computer is designed to run off a full manifold vacuum signal, not a ported one. Try hooking the computer up right and see if you notice a difference.
PostPosted: Thu Apr 23, 2009 9:10 am
The port the arrow points to is the venturi port.No vacuum at idle.Strong vacuum at part throttle.Varies the vacuum more than the manifold vacuum.I hooked my vacuum advance to the port shown.[HEI conversion].
PostPosted: Thu Apr 23, 2009 10:12 am
That's the venturi vacuum port. It's supposed to go to the EGR vacuum amplifier (hockey puck looking thing), possibly via valves or switches depending on year and configuration. Not to the ESA computer and not to the distributor.
PostPosted: Thu Apr 23, 2009 2:09 pm
Oh sorry. Wrong photo..
The red arrow one is hooked up to the EGR amplifier.
The larger one below and to the left is hooked up to the ESA.
The above picture (from the posted Holley manuals) says it goes to the vac advance. My original carb has that same port, and the diagram under the hood says it goes to the ESA.
PostPosted: Thu Apr 23, 2009 3:34 pm
Whatever the Holley book and your underhood sticker says, the computer needs a manifold vacuum source, not a ported vacuum source.
