It is currently Sun May 10, 2026 10:43 am
PostPosted: Thu Apr 23, 2009 11:33 am
Removed my instrument cluster in my '73 D-100 pickup to repair some heater wiring. When getting ready to put it back, I noticed what appears to be a capacitor hanging off one of the studs for the heater gauge. The body of this cap was hanging loose. The screw tab on it's side can only reach either a ground screw on the body of the cluster, or the blue wire at the ammeter. i assume it goes to ground and NOT to the ammeter. Right? And what is it for? Thanks!
________
colorado dispensaries
PostPosted: Thu Apr 23, 2009 12:17 pm
Radio noise suppression capacitor so you don't hear the snap-crackle-pop of the instrument cluster voltage limiter points making and breaking. Not needed if you upgrade the limiter.
PostPosted: Thu Apr 23, 2009 12:54 pm
So the loose end indeed goes to ground?
________
Honda CBR1000RR
PostPosted: Thu Apr 23, 2009 2:38 pm
Yep, it goes across instrument cluster voltage limiter and ground.
PostPosted: Thu Apr 23, 2009 4:38 pm
Errr....no! I have that one two, but this is a seperate one (looks just like the regulator one) which has a small, round, push-on connector to one leg of the temp gauge. This leg goes directly only to the large milti-pin connector in the center, and I'm guessing It's the signal input to the gauge. Would it help if I attached a pic? I'll shoot one and post it here shortly.
Well, it appears that I don't know how to insert an image. How?
________
vaporgenie
PostPosted: Thu Apr 23, 2009 10:04 pm
Instructions here.
