It is currently Mon Jun 15, 2026 5:03 am
 Post subject: vacuume removal
PostPosted: Thu Apr 23, 2009 4:13 pm
Hi, I was wondering what all vacuume lines I can remove on my engine? I know I need vacuume advance line, carb to choke line, but what all can i remove without compromising my engine? Can I plug the small line that comes off of the brake booster or will that mess it up? Also, can I plug the line that is right next to the coolent sensor? What exactly is that for?
-- Mister Perkins --
Pictures of my truck
http://www.cardomain.com/ride/3257131p
PostPosted: Thu Apr 23, 2009 4:22 pm
There should be a map of the vacuum hoses under your hood. The vacuum line to the brake booster is required for the power brakes to work. You need the vacuum advance to the distributor, the PCV, the choke pulloff, and possibly the charcoal cannister.
PostPosted: Thu Apr 23, 2009 4:24 pm
Why do you want to pull all of that stuff off? Is something malfunctioning?
Taking the line off the brake booster will make those brakes rock hard to push...
~THOR~
PostPosted: Thu Apr 23, 2009 4:45 pm
nothings malfunctioning, I just want the engine bay to look cleaner. Vacuume lines running everywhere is kinda crappy looking. I know most of the vacuum lines are needed.
Well, there is something that is going wrong. All of my vaccum lines are running to the right spot, but if I sit there and pump my brakes up i can hear a popping sound in my exhaust. Once I let off of the brakes it stops. It has a new master cylinder on it, but the brake booster is origonal. When I replaced the master cylinder, I didnt notice anything leaking out of the booster, and the rod looked alright. A little rusty, but decent looking. Do you guys think my brake booster could be faulty causing it to suck air in or something? It did this before I replaced the master cylinder too, but I didnt replace it because of that. I was replacing all of the lines/brakes and wanted the master cylinder to be new as well.
Well, I guess does anyone know a good way to hide all of those vacuum lines?
PostPosted: Thu Apr 23, 2009 6:15 pm
Do you have a vacum gause installed? If so, what is your idle vacuum reading? There isn't any real way to hide the hoses.
PostPosted: Thu Apr 23, 2009 6:31 pm
no vacuum gauge installed. I should probably get one though..
PostPosted: Thu Apr 23, 2009 9:58 pm
Uh..yeah, kinda gimme a break and stuff, eh? The more random parts you remove, the "cleaner" you may think your engine bay looks. Keep at it and there'll be nothing left in the engine bay and it'll look super ultra mega "clean". What's the point of this exercise?
Yup, if you sit there pumping the brakes, you'll be letting a whackload of air into #6 cylinder, causing that cylinder to run super lean and misfire. Do you have to pump the brakes to make them work...?
If you gotta-just-gotta, then bend up some shiny metal hardlines with straight runs and neat 90° and 45° bends, and connect them at ends with short lengths of silver, red, or blue silicone vacuum hose. Is it really worth the effort...?
PostPosted: Fri Apr 24, 2009 2:20 am
Mister Perkins,
Now that you have introduced yourself to a new truck, sell it and get a swepty (1960's sweptline series). Nothing to hide because there is nothing there. NOW you can work to your heart's content on the same engine with enough room to sit on fenders and work inside. Better trucks for my money too. Take your fist and hit a swepty fender and listen to the thud. Then hit the new stuff...all tin. (Don't hit it too hard or it will dent).
Half kidding you, but the bare bones approach of the sweptline makes it much more tweakable, and there are no funny parts to try to get and no funny ignition. Look at the pic of mine...it is now a show truck that gets out and runs ever now and then.
rock
'64d100
PostPosted: Fri Apr 24, 2009 6:12 am
Rock
You have a PM
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Apr 24, 2009 1:27 pm
Good idea dan. I think I might do that. I am trying to make the engine bay look tidy. I think that the metal tubing approach might be a good idea. I'll just run all of the vacuum lines inside of it. Thanks for the idea. Well, the main reason why wanted to do this is because I am going to be pulling the /6 out soon and rebuilding it top to bottom. Painting the engine, re-installing it. Also am going to repaint the entire truck off frame restoration. Doesnt need any fixing, just want to scale the frame, sand blast it, powdercoat it and reinstall everything.
PostPosted: Fri Apr 24, 2009 3:12 pm
Mister_Perkins,
You have a PM.
Users browsing this forum: Amazon [Bot] and 3 guests
